Weak Loader or what
/ Weak Loader or what #41
Tony, I don't think you'll be in any danger if you disconnect quick connects and install a gage. Your system pressure relief seems to be installed in the plate where your hydraulic oil filter attaches. I don't know how the Doall loader is plumbed, but you can look at and verify your locations and components by going to this website and entering "585" in the model block. You'll see a list of tractors including the older International 585. Choose the Case 585 and then look at the pictorial index. Your hydraulic system piping is shown in several of the drawings. For detail view, go to the Hydraulics section and click on the specific items. I believe you'll find that pressure relief is built into your pump and filter base or some other location that is still in the system when you disconnect the loader. Otherwise, if you ever remove the loader from your tractor you would have to do a complete replumbing to add a relief valve to your tractor. I don't think that would be prudent design.
I just hooked up the pressure gauge to the remote ...the pressure read the exact same as it did when I had it hooked to the disconnect for the FEL. I raised and lowered the 3pt hitch while I had the tractor at 1500 rpm. raising the 3pt would be a 200 psi drop until it finished travel then the pressure would return to previously listed . there is no difference in noise no stalling no change in RP M's when the loader maxed travel or when the 3pt topped out the travel...I tried several times to hear the pressure relief valve engage I don't think it is ...I don't think there is enough PSI to engage the pressure relief valve .
/ Weak Loader or what #43
Maybe the relief is just cranked open a little right now.
/ Weak Loader or what #44
Any tractor using hyd will have a relief valve. If there is no loader, there is usually a relief valve at the 3pt . There could also be another relief valve at what some call the hyd block like on the Kubota's. The first relief valve after the pump is what sets the tractor relief pressure.
So if you install a loader, and the flow comes from the hyd block, that will be the master relief, you would then set the other reliefs to match the master relief.
I am assuming that there was no load on the 3pt when you were doing the test. If you just raise and lower the 3pt with no load, you will only see very little pressure.
When you pulled the lever to raise and held it there you said the pressure only went to 1200 psi. Correct
I still think you should take the pump to a hyd shop and let them do a pressure and flow test and give you an estimate to rebuild if needed.
Your 3pt cyl probably needs new seals also.
Your tractor will work with some GPM's, and some pressure caused by a worn pump, but you will know the difference with a new or rebuilt pump and new seals on the 3pt cyl.
It is a good idea to take a hyd gage with you when buying tractors, because the seller will say just about anything to sell a product.
/ Weak Loader or what #45
If that valve has PB, the relief valve leaking can be checked. The relief only passes fluid when the pressure is above the relief setting, and that occurs when the cyl is maxed out, or something is blocking fluid downstream.
The OUT port will only pass the cyl expended fluid to tank and/or the relief pressure over flow.
So, remove the OUT port hose hose. If the relief valve is leaking there will be fluid flowing from the OUT port with valve in neutral, and engine running.
/ Weak Loader or what #46
Good point..:thumbsup:...I've seen a few customers come in to my place wanting the cheap way out on fixes.....just to find out the machine is going bye-bye to an auction, traded in, or sold....:banghead:......some people don't have any problem pushing their troubles to someone else
They know if it was running great it would probably still be setting in their barn
Yeah...all good points. My family says that I always try to run potential buyers off when I sell something by telling the buyer every little thing that is wrong. But I know how I feel right now; and, I don't wish that for anyone. That being said , I plan to make this tractor a keeper so I would rather bite the bullet now then have it go down when I need it most.
Thank you guys for all the help...Merry Christmas.
/ Weak Loader or what #49
After I took my pump apart, I could see it was worn, but didn't know how much so I took it to a hyd tech and at a glance, he said you might as well buy a new pump as it will cost you more to do a major rebuild.
I went ahead and ordered a new pump.
Old pump out ..new pump in! I had to remove several metal "hard lines" in order to remove the multicontrol valve and hyd pump. Question: is there any particular way to bleed the system...I mean it is a full of air now; and, do I need to worry about cavitation?(sp).
/ Weak Loader or what #51
If your pump has fluid at the input, as you work the hyd, the air will self purge.
Well...like I said...replaced the hydraulic pump and the loader and three point still seem weak. Borrowed the guage from the case dealer today. Before pump replacement, I'd get 1200psi at 2000rpms, now; after installing the new pump, I get 1600psi at 2K. The dealer service guys say I have a bad PRV...they said that CaseIH came out with an improved valve. They are going to order one for me and if it doesn't solve the problem they will let me return it for a refund (can't beat that). What do ya think J.J?
/ Weak Loader or what #53
Do you know the pumps rated pressure?
Did you set the relief pressure.
Did you check/set the 3pt relief.
If the PRV is bad, just replace the PRV.
How did you do the test.
Was the cyl you used, a leak free cyl.
A flow and pressure test would be a good thing.
I did not set/change any existing relief pressure....The 3pt does leakdown at idle...so maybe that cylinder is leaking. I'll let you know what I find on Monday when the PRV comes in.
well I just replace the pressure relief valve ..made no difference in the amount of hydraulic pressure ...
I am thinking that I have an internal leak....I pulled the plate off that is under the set and I could see the fluid circulating down in the cavities but one cannot see the actual pump. Case dealer tol me to pull off the MCV AGAIN and make sure I don't have an O ring out of place. Dealer said I should have much more pressure that 200psi at idle no matter where i test it. I'm definitely getting a crash course on hydraulics....at this point, I am ready to burn my barn down with the tractor in it!
/ Weak Loader or what #57
Do you have a known good cyl to do some testing?
Do you have a hyd gage installed in a tee at the IN port of the FEL valve?
If so, run a hose to the good cyl from the work ports, start engine rev rpm's to 2500,and pull lever back for that spool until the relief valve squeals, and tell us the pressure.
Next test, with the FEL valve lever in neutral, raise the 3pt until the relief squeals, and read the pressure.
Have you asked the dealer what the pumps max pressure rating is?
/ Weak Loader or what #58
I'm kinda agreeing with the dealer where you may have something out of place.....You may need to find another trained set of eyes and hands when it comes apart for comfort.....look over all tubing and fittings too
with everything mounted internally it may be by-passing back to tank prematurely
JJ the pressure reading doesn't change at max rpm even when the relief valve squeels. replace the pressure relief valve with a brand new 1 and did not make any difference . Going to carry her to the dealer in a couple weeks ,do a flow test ,and go from there. A special thanks to both of you for taking time to entertain these questions . I will let you know if and when I get it resolved .
/ Weak Loader or what #60
Have you removed the hoses on the work ports and looked inside and also into the fitting to see if there is a restriction. Maybe they did poor machine work on the valve.
Have you removed the spool from the valve, otherwise, remove the bottom metal can, remove the float section, and spring centering section and actually pull the spool out of the valve?
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
43024 (A59228)
43024 (A59228)
Challenger 35/45/55 Parts and Operation Manuals (A63117)
Challenger...
Caterpillar 943/953 Track Loader Service Manuals (A63117)
Caterpillar...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
