Way to Fix Rattling in Titan Ballast Box Receiver?
   / Way to Fix Rattling in Titan Ballast Box Receiver? #1
Suburban Plowboy
FL
Kubota L3710
Is there a product that will keep things from rattling in this 2" ballast box receiver?
   / Way to Fix Rattling in Titan Ballast Box Receiver? #2
If understand correctly from your post I had a similar issues with a truck a while ago.... the receiver slot was just a touch too big for the trailer hitch post causing it rattle going down the road.
Home Depot carries red rubber packing sheets (6"x6") in the plumbing section. I cut rectangle out of one of those sheets sized to fit the receiver and slide it in there with the trailer hitch. It took up the extra space and cut down on metal on metal contact basically eliminating any noise caused by parts shifting around.
Thanks for the suggestion.
This box is unusual because the receiver doesn't stick out, so there is not much to clamp to.
I found a shim kit made for this purpose. I'll link to it in case anyone else needs one.
   / Way to Fix Rattling in Titan Ballast Box Receiver? #4
anti-rattle hitch tightener? harbor freight sells them for $12. i've never used one, and have no idea if / how well it works.
The problem is that it has nothing to grip.
   / Way to Fix Rattling in Titan Ballast Box Receiver? #6
it tightens around the drawbar. the flat edge of the plate goes under your box, the angled up end goes under the drawbar, tightening the hex nuts will pull everything tight.
Thanks for the correction. I see now.
After I wrote the last post, I realized that clamp would prevent me from setting the ballast box down. The internal clamp I found wouldn't be in the way.
   / Way to Fix Rattling in Titan Ballast Box Receiver? #10
Weld legs on so the box sits higher of the ground, and us the HF clamp.
Or weld in the draw bar.
   / Way to Fix Rattling in Titan Ballast Box Receiver? #11
Maybe a good hit with a ball peeing hammer on the tubing from the underside to adjust the fit of the assembly.
Of course, proceed with care... Could be hard to re enlarge the hole.
The kit from Amazon arrived, and when I tried to install, it I found out the carrier is already set up for rattle prevention. The manual didn't say anything about it, so I just assumed.
One side of the tube that goes into the receiver is threaded, so you when you insert the bolt, you tighten it, and it jams the tube against the receiver.
UNUSED IRANCH MINI HYD AUGER SET (A60432)
UNUSED IRANCH MINI...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A59230)
2016 Freightliner...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
