CurlyDave
Elite Member
CurlyDave,
Just got mine hooked up about an hour ago. I agree about inlet/outlet system. That made things very difficult. How is yours doing so far?
I got mine hooked up about a week ago.
I only put 4 bags of salt in, just in case something goes wrong and I have to empty it out.
Two problems so far.
1. I don't know the exact hardness of our water, which is needed to set this up properly. So sometime later in the week I have to take in a sample to get tested. And,
2. There is a slight leak at the outlet of the water softener. I hooked it up with 1" pex and the tubing is putting some force on the outlet fitting, which is a funny plastic contraption with an o-ring seal.
The way to get this to relax into the right configuration is to drain the pex line and heat it with a heat gun until the pex turns clear. If I don't touch it as it cools, the pex will go back into position without this extra force.
I have been postponing doing this for a while while I figure out how to keep the heat away from the plastic fitting in the water softener, but I have an idea now and will do it in the next day or so.
P.S. If a moderator ever reads this, the spell check software is giving me a fit. Every time I enter "pex", it automatically gets edited to "per". Sort of an automatic misspeller. Is there any way to suppress this behavior?
