water pump bearings
/ water pump bearings #1
miatamark
eastern part of Iowa
john deere 855
Does anyone know where I can find water pump bearings for a John Deere 855. I have the bearing number, have just been unable to find a vendor. Or if anyone knows of a salvage yard that specializes in compact tractors.
/ water pump bearings #2
If you have a bearing number, you should be able to go into any place that carries bearings (like auto parts or maybe machine shops) and get a replacement.
The water pump bearing number is WB1226102. There is also an GAG number, but they don't make it any more.
/ water pump bearings #4
Good luck finding parts for these pumps. By the time you source the parts and then pay a machine shop to press everything off and then back on you might as well buy the new unit form JD if they have them. Many parts for these JD/Yanmar engines are extinct.
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
Barrel (A64557)
Barrel (A64557)
2003 Jeep Wrangler 4x4 SUV (A64557)
2003 Jeep Wrangler...
2012 MULTIQUIP DCA-7OU512 TOWABLE GENERATOR (A63276)
2012 MULTIQUIP...
2001 Peterbilt 378 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2001 Peterbilt 378...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
