Water line leaking - how to find it
   / Water line leaking - how to find it #31
Helped a friend when he was building and asked why so many shut off valves and hydrants from
Meter to home?
Every 150’ he had a box with a line shutoff and a riser with a hydrant shutoff.
He said it’s 900’ and if I have a problem down the road I cans quickly isolate the location to within a 150’ plus point to point I know exactly the run.
It doesn’t freeze here so no worries about that.
   / Water line leaking - how to find it #32
Meter to home?
I dont know I would go every 150 feet; but every 500 ft would be a good idea. Yes, there is some Marginal reduction of flow (pretty darn marginal); but it gives you options. Looks like between $9-45/valve, depending on type/material.
   / Water line leaking - how to find it #33
It was also to have water readily available for future projects and irrigation.
Just about everyone I know has had a meter to house line break and I have replaced my shared of 80+ year old 1/2 galvanized in the city… lucky the runs always less than 60’ copper coil and I attached the copper to galvanized and pull out the galvanized on one end while feeding the copper in the other.
   / Water line leaking - how to find it #34
Yep, at the valves; I would add a tee and 6" long stub and cap, or a tee, to a 3/4" valve and riser with hose bibs (or those frost free hydrants or whatever).
Big picture, we have $6000 in just pipe, probably another $3000 in labor; what's a couple hundred in valves and stub outs for future use.
   / Water line leaking - how to find it #35
All,
Thanks so much for your replies. As for why I think I have a leak are these clues: (1) we had a leak in the line before. We knew because our water usage went WAY up one month ($1,000), and there was a place visible in the pasture which was green and wet while elsewhere the pasture was still brown, (2) just this month we accidentally were given the water bill for our neighbor as well as our own. The neighbor's bill was something like $30 while ours is $200. They have 3 people in their household while we only have 2. We don't water our lawn or a garden, and only have 2 dogs and 4 chickens to water besides us humans. (3) After seeing the neighbor's water bill, I cut of all water at the house (which I installed when I had water issues before), then went to the gate to see if the water meter was turning. It was. (I took a phone video of the meter but it was too large to upload - 24 MB.) It is not turning fast but steady enough to cause our water usage to much more than needed.
Regarding locating the pipe, one thing that might help is that the old phone lines were buried next to the water line. The phone lines are being used (edit: are NOT being used), so I or someone else might could use them to send a signal that could be detected.
If I am able to locate the leak, then I will most likely try to repair it.
Thanks again for all of your replies.
Senile Texas Aggie
There are several ways to locate wire buried underground. You could do a web search. Never mind, I just did one. This link is for one device but there are several similar devices: https://www.amazon.com/Underground-...nEWAT6sRPF8zWeMKB7-sRIlBxfBoCOoEQAvD_BwE&th=1
Anyway, I know because of the way the radio signals work the depth of wire that can be found varies. Wet soil has a negative impact on how deep the cable can be detected. Anyway, these devices all work the same. They send an audio signal that is modulated so as to be picked up by a radio receiver, usually in the AM band if memory still serves me. You need to connect the sender to one end of the cable and I think it is best if the other end of the cable is disconnected. (In fact I'm sure it is best to have the cable disconnected at both ends. The longer the cable is the more the signal can be attenuated and this weakened signal will be harder to detect. So find each end of the cable and disconnect it from anything else. It is not being used anyway.) This then makes the cable an antenna that broadcasts the signal fed into it. Then you wave the receiver over the ground until you hear the tone and where it is loudest you are closest to the cable.
Eric
   / Water line leaking - how to find it #38
All,
I reside on 160 acres in western Arkansas. My driveway (and water supply line) is about 1/2 mile long. The water line is leaking somewhere between the gate and the house but I have not found where. The water line is about 20 years old and so the seals around the PVC may be leaking. I forget the name of this type of piping, but the piping is not glued to each other. Instead a 20' section of pipe is made with a male end and a female end. There is a gasket (O-ring) in the female end that seals the male end of the next pipe. These pips are laid out and then covered over, They work great as long as the ground is not disturbed and the seals don't fail (which apparently starts to happen around 20 years).
My problem is that I don't know exactly where the water line is buried. I know where the line is about 1/4 of the way from the house, as it leaked there and was repaired back in 2020 (that was an adventure but a story for another time). The water meter is located at the gate, so that is the other end. But where the line is in between is a mystery. I see no signs of leakage in the pastures, but the water line crosses a small creek at an unknown place, so it may be leaking there. We had a really dry summer and there was no sign of water entering the creek, as it was completely dry, but maybe the trees there are absorbing the water that is leaking.
So what do you folks recommend: (1) find the leak and repair it, (2) replace the entire water line with a water line that won't use gaskets/seals that will deteriorate, (3) something else?
All recommendations are welcome. Thanks in advance.
Senile Texas Aggie
Did you have any luck with your waterline? I am really curious as to the outcome.
   / Water line leaking - how to find it #39
I know I am a little late on this but here is how I did it. My 1.0 dia. water line was leaking some where. The water pump would cycle on and off, not that often but enough that I knew I had a leak. The line was approx. 150 ft. long and it was the water line to my building.
I borrowed a tool from the shop that we used for finding air leaks in the in the welded piping of assemblies. With this tool we could find leaks without using a soap solution. It had a set of head phones and a pistol like receiver. All of the electronics were in the pistol. You would walk down by the assembly pointing the pistol at different joints and it would sound in the head phones when a leak was detected. It was looking for the high frequency sound that an air leak will will make.
What I did differently, unless I missed this in the previous suggestions, was to drain the water out of the line and hook up my air compressor to the line. I didn't get all the water out but the idea was to have the air make the high frequency sound which the water would not. I walked out to the approx. area where the line was and the head phone started sounding the minute I got close to the leak. The sound was like rumbling as the air would spit out of the pipe underground along with some water. I had a section of the plastic pipe about 2 feet long that was just perforated with really small holes. So this process worked for me.
I thought I could use this type of tool to check for leaks in tires. I purchased similar type of device but it didn't work on the tires. It had a specification like 50 psi with a .005 hole size. It works for air leaks in cars around doors, it has a transmitter you put inside the car etc. That all I can remember. Later.
   / Water line leaking - how to find it #40
My brother has a leak from meter at street somewhere to his house...I'm guessing 100 ft. or so. Today he shut main valve off in basement and meter was still running, not a lot but a leak somewhere. He's a few hours from me though. Disconnecting line and compressed air is a good idea to try.
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
SCREENER (A58214)
SCREENER (A58214)
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
Mini Margaritaville Truck (A55853)
Mini...
