water in tires
   / water in tires #1
johnvickl
Bronze Member
bought kubota 7040 it has water and antifreeze in rear tires want to remove and put in multiseal. do i have to get all of water out? thanks
   / water in tires #2
Are you having leaks? I've not heard of using multiseal in full size tractors. (I'm assuming that is one of these products that seals small to medium size punctures)
   / water in tires
no leaks, kubota tells me the multiseal works great for thorn punctures etc. everything in south texas will stick you. i had slaime put in my last tractor thanks,, john
   / water in tires #4
I guess I'm just not familiar with Texas sized thorns. I have R4 tires and cannot imagine what kind of pre historic dino thorn would be needed to puncture them.
If I were in your shoes though I would remove the water as the viscosity of the slime type substance is important in forming a seal and you wouldn't want to dilute it. I'd guess the manufacturer could give you advice too.
   / water in tires #5
i think i'd wait til i had a leak before i changed anything, who knows you may never have a puncture at all.
   / water in tires
thanks for your help i will leave the water and antifreeze in until something wierd happens thanks
   / water in tires #8
Locust thorns here in Texas can grow to several inches long. Finding a thorn longer than your hand is common. Mesquite are not large compared to Locust.
   / water in tires #9
We get some gnarly thorns here - choke cherries get some pretty long ones that can puncture an ag tire when they hit it right. I filled my front tires with foam when I put my second set on the rims. I highly recommend that.
When you puncture one of your water filled tires it'll probably act like a squirt gun. It's pretty easy to spot the hole :). Don't ask me how I know...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
CAT JUMP BOX (A53843)
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A51694)
2009 Mariah SC23...
2012 Dutchmen Voltage V3950 42FT 5th Wheel Tri-Axle Toy Hauler Travel Trailer (A51694)
2012 Dutchmen...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
