JonnyH
I have water in the hydraulic system. Grey slurry. How to get rid please and how to go about it.
I've seen this suggestion mentioned more than once, so I can't help but ask. Have you actually done this with any success at all? My experience with water contaminated transmissions has shown the fluid can be drained, refilled, drained, refilled, possibly four of five times and watery oil is still present. One change, prolonged standing and simply draining of the remaining water at the bottom simply doesn't work. That yuck is everywhere in the system and takes nearly forever to work it all out.instead of changing a 2nd time, wait till the tractor's been sitting cold several days, then briefly remain drain plug to remove moisture that will have collected on bottom of sump, then top off. when the hyd fluid is warm, the fluid goes grey from the water mix. good luck & get a new gear boot & keep covered, regards
Drain, change the filter(s) flush with new fluid start to run the fluid through the whole system, then cycle everything at least twice. let it sit for awhile then drain and put the drained fluid in in a clear container and if you see any water or anything at all, repeat the above until you don't.I have water in the hydraulic system. Grey slurry. How to get rid please and how to go about it.
Just so you know Jonny, no politics allowed on this site.Hi guys.
Thanks to you all.
Watching a special event here in UK......on my tv. Madison Square Garden.
Amazing evening here seeing this important time in the USA.
Praying that DJT & JDV to win big.
My regards to you all.
Jonny H
Cheltenham
UK
The hydrostatic drive is part of the same hydraulic system, if you don't flush it you leave water in it.I have never done this but had old timers tell me it works.
Several old timers I have know swore using diesel fuel as a flush fluid with some Heat would remove the sludge and moisture from the hydraulic system of the tractor. According to them any cylinders needed to be cycled several times and the 3 PH should also be cycled several times.
So drain system, flush with diesel fuel, drain system fill with hydraulic fluid and change all filters and clean your screen.
According to those guys you should be good to go.
Again this is an untried procedure by me.
I probably would not do this to hydrostatic drive system, fearing pump damage.
Never meant to imply I would not flush a hydrostatic drive. I apologize if I implied that. I merely meant that I would not flush with diesel fuel on a hydrostatic drive.The hydrostatic drive is part of the same hydraulic system, if you don't flush it you leave water in it.
While I agree that all cylinders (which includes FEL cylinders) should be cycled (several times) as a part of the flush, leaving the loader in a raised position has little to no effect on the amount of oil that is in the cylinders on a dual action (hoses at both ends of the cylinder) hydraulic cylinder. The rod is pushed in both directions by hydraulic oil. In reality there is slightly more oil in the cylinder with the rod extended as the rod is not occupying space (volume) inside the cylinder.Once you have water emulsified with oil, you will never get all of this out with one flush.
Go to Tractor Supply and get their cheapest hydraulic fluid that applies to your machines criteria. You will need 3 oil changes or at least two and two hydraulic filters.Figure the oil changes are cheaper than any other fix. First thing: change out hydraulic filter first as original is all gummed up with the emulsified oil. Drain contaminated oil. Refill and Run the tractor extensively getting the fluid good and hot. If your machine has a fel, raise the fel as high as it will go when you drain the system so you get a degree of drain back. This is still a pressurized system until you shut the tractor off and blip the joystick a couple times to relieve some pressure build up.
Fill it back up and get the fluid hot again. Drain it out. Fill it back up , drain it with same technique as above.
Now put in a good hydraulic fluid and with a new filter, you should be good to go.
Also, fix the leak points of water contamination.
