Water in Hydro
/ Water in Hydro #1
Freddi
Columbus, NC
Bobcat 763
I have a Bobcat 763 and water has gotten in the hydro fluid is there a drain location or locations that will purge the max hydro fluid? or is there a method of getting the hydro out and cleaning the lines?
/ Water in Hydro #2
Drain the main tank, drain the return filter housing. Don't change the filters yet. Refill with a cheap hydraulic oil with the correct spec., run the machine hard for a couple of hours to get the oil hot. Drain the oil and change all of the filters. I would not mess with any lines but if you do, do NOT touch the hydrostat lines it is not worth the chance of any contamination. What little water that is left in the system will evaporate out with use as long as no new water gets in. That's why it is actually good for the hydraulics not to run too cool. CJ
/ Water in Hydro #3
CJone is correct on the water removal procedure. My question is, were did the water come from or how did the water get in your system? Cleaning it won't help if the problem returns due to a missing vent cap, etc..
/ Water in Hydro #4
Or a oil to water cooler that is leaking internally. CJ
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Lowe Quick Attach Post Hole Digger (A66285)
Lowe Quick Attach...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
6 1/4 INCH OD 90...
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
