Water Hose Storage
/ Water Hose Storage
I have 2 of those as well, but with about 500' of hose on each. The main degrading issue on this type of cart is, as you suspect, internal rust from water that seeps into the tubes collects and eats the bottom tubes. On these carts the bottom tubes are not continuous. They join at the middle giving water a way out. Also since this makes the tubes shorter you can more easily pre-treat the inside by spraying in a wax based corrosion inhibiter.
Mine spend the spring and summer outside and after 5/6yrs are fine. The flat free tires are great because they are maintenance free. --- Also note that you can mount the reel pivots to the underside of the tubing to make the reel hang lower. Iv found no disadvantage to doing this.​
Sorry, got distracted and forgot about this post. Thanks for the reply, I think with your info and Rnady's info I've decided to seriously look into one of these for my current hose and then get something lighter for the wife. I do not want to give up my big hoses so this sounds good.
2025 80in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
KBH Tank Trailer (A61307)
KBH Tank Trailer...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
John Deere 2155 (A62177)
John Deere 2155...
TANK MANIFOLD (A60736)
2019 John Deere 4044M (A62177)
2019 John Deere...
