Water Hose Storage
/ Water Hose Storage
I have 2 of those as well, but with about 500' of hose on each. The main degrading issue on this type of cart is, as you suspect, internal rust from water that seeps into the tubes collects and eats the bottom tubes. On these carts the bottom tubes are not continuous. They join at the middle giving water a way out. Also since this makes the tubes shorter you can more easily pre-treat the inside by spraying in a wax based corrosion inhibiter.
Mine spend the spring and summer outside and after 5/6yrs are fine. The flat free tires are great because they are maintenance free. --- Also note that you can mount the reel pivots to the underside of the tubing to make the reel hang lower. Iv found no disadvantage to doing this.​
Sorry, got distracted and forgot about this post. Thanks for the reply, I think with your info and Rnady's info I've decided to seriously look into one of these for my current hose and then get something lighter for the wife. I do not want to give up my big hoses so this sounds good.
2022 EZ-GO ELITE...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
(INOP) TAKEUCHI TL10V2 SKID STEER (A64280)
(INOP) TAKEUCHI...
