Washer Fluid?
/ Washer Fluid? #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
Any concerns with using washer fluid as ballast?
RimGuard isn't available within an hour or more of me...despite what their advertisement has you believe...
I can get bulk washer fluid from a company a mile down the road....probably better than nothing - unless I'm not aware of a risk with that?
Should I have tubes added or not necessary?
/ Washer Fluid? #3
Never used it in a tractor, but I did use washer fluid to load the rear tires in my rider mower. Just used the -20 stuff you get at Walmart. Been 10 years or so and no problems.
/ Washer Fluid? #4
Any concerns with using washer fluid ??
No... I did a DIY install of 25% antifreeze and 75% washer fluid.. The anti freeze used because of our growing zone 2 winter temps..
This mix is not as heavy as other alternatives, but much more available, cheaper materials and not hard to DIY install... Just some what time consuming to do..
/ Washer Fluid? #5
Same here.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
