Wash and WAX???????
/ Wash and WAX??????? #21
Jay,
Summer- the Kids have a 2 seater go-cart that gets kept in the garage attached to the house with the wife's family station wagon The Bota stays in the pole barn. Winter- kids dont use the go-cart so it goes into the hog pen, and the Bota moves to the garage , it isn't heated directly, but is insulated and usually never gets below 55 degrees in the winter unless the big door is open all day.
Bota has never been kept outside, (I've never made any of my kids sleep outside either), but at one time I had my Case DC outside, and I had an old bedspread I would cover it with and then cover the bedspread with a waterproof tarp.
I really think between the elements. . . . sunlight is more of an enemy to the finish then rain or snow, while rain and ice hurt the moving parts and seals, cylinders....
I had a 1947 Case DI (was going to restore) that sat outside with no tarp for 6 months. The shifter boot (rubber seal in the gearshift lever) looked in good condition. . . but actually had a few hundreths gap. When it would rain, water would drip from the steering wheel to the shift levet and follow the lever to the boot, making its way to the transmission. It then displaced the gear oil and filled the gear case to the top (in less than 6 months). The first hard freeze and the gear case cracked, (top cover popped off). Ended up parting out the DI.
So yes, I keep all outdoor stored equipment covered, including my 2 bottom plow, and my disk harrow.
Steve
/ Wash and WAX??????? #22
Glueguy
I use some stuff called Wesleys Bleach White. Same theory as your stuff. Spray it on, use a bristle brush or rag, rinse it off and WOW!. Also works good on wheel covers.
I'm at a loss for a name too. Seems like it was easier to come up with names for the children than for the Bota. . . . .I guess when it happens, we will know it!
Steve
/ Wash and WAX??????? #23
Jay, I'm fighting my second round of poison ivy in three weeks /w3tcompact/icons/frown.gif What did the doctor do for you and did it help?
Itching in Indiana /w3tcompact/icons/smile.gif
/ Wash and WAX??????? #24
Re: Broke my foot!
Pete, that's a real bummer /w3tcompact/icons/frown.gif
I broke my ankle a couple of years ago and turned it into an opportunity to buy implements! I couldn't push the fertilizer spreader, so I got a pull behind model for my lawn tractor. Maybe you can use your foot to your (tractor's) advantage /w3tcompact/icons/smile.gif
/ Wash and WAX??????? #26
Does anyone wash the engine? I keep the tractor wash and waxed but don't know if it is ok to get the engine wet.
James
/ Wash and WAX??????? #27
James, I use a product called PURPLE POWER and I spray that on first and then wash off the motor. It removes all the dirt and grease that might have built up on it. If you do it all the time it will always look like new. The water will not hurt it one bit.
/ Wash and WAX??????? #28
I haven't washed my engine... yet. It won't hurt the engine to get it wet but I'd watch two things: Don't wash it when it's hot. The cold water hitting hot engine parts could be a problem. Also, don't use a power washer. It could force water into seals, gaskets, electical connections etc. If I ever do wash the engine, I'll probably attack it with a bucket of soapy water and brushes of various sizes then rinse with a gentle shower of water from the hose.
Are you going to wax the rocker covers /w3tcompact/icons/smile.gif
/ Wash and WAX??????? #29
Rob, Von, Thanks for the info. No, I don't think I will wax the rocker covers. thanks again.
James
/ Wash and WAX??????? #30
I wash the engine every time I wash the exterior, which is just about every time the tractor gets dirty./w3tcompact/icons/smile.gif Most of the time just with the spray nozzle on the garden hose (about 80 psi), but sometimes with my hydro air gun (hook the garden hose to one inlet and a 90 psi air hose to the other).
Bird
/ Wash and WAX??????? #31
<font color=blue>Are you going to wax the rocker covers</font color=blue>
Actually, I thought I'd get them chromed. /w3tcompact/icons/laugh.gif
The GlueGuy
Re: Broke my foot!
Boondox,
That's all that matters. Clementine needs her exercise. Let her do the work.
Jason
RobS,
The Doc gave me Prednisone for my poison ivy which is a steroid. It quickly dryes and reduces the swelling of the poison ivy. Because I had it in my nose and around my eyes I felt that benedryl wasn't powerful enough. I believe in the Off Subject chat they talk about several differnt over the counter drugs the work quite well. On top of Benedryl I also use Rhuli Gel. A clear liquid that reduces swelling and dryes poison ivy. I hope this helps. Good luck
Jason
Re: Broke my foot!
Boondox,
I think I will put a cast on so all outdoor work envolves Jezebel. She gets lonely outside during the week. I only have 13 hours on her and have had her for close to a month.The beers won't hurt either.
Jason
Von,
Where do you get that Engine Wash Purple Power? I can't seem to find it at the local auto parts store.
Jason
/ Wash and WAX??????? #36
Jason,
I get it at my local auto parts store. It might be in
BJ's or SAMS club as well. Its pretty cheap, 2 1/2 gal. for 8 bucks. I use it on everything, cut it with water 50-50 and it works great on getting the mower deck clean, as well as the BBQ. hunt around for it, I think you will like the way it works.
/ Wash and WAX??????? #37
I don't know about Engine Wash Purple Power - but I came home the day before yesterday and found purple crayon all over my BX. One of my 2 year olds decided it was coloring time and snuck out to the garage I guess. I hear WD40 works well for crayon - I'll let you know ... /w3tcompact/icons/crazy.gif
Von,
I will find it thanks. The way you describe it's cleaning ability has got me on the hunt. Jezebel likes to be cleaned after she gets dirty. If there were only a cleaning agent for me.
Jason
/ Wash and WAX??????? #40
When we were building six years ago, my daughter (then 5) was sent to the trash with the old paint brush I had been using. On the way to work the next day, I was pulled over by the State Police as "somebody" had painted over my lisense plate and part if the bumper in the back with white enamel. When I saw it I started laughing and explained to the trooper and he let me go, making me promise to have HER clean it up that night. Yes, better you had crayon.
Steve
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
TEREX TH8440 TELEHANDLER (A60736)
TEREX TH8440...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
6 Band Wooden Barrel (A61569)
6 Band Wooden...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
