3-Point Hitch Was bush hogging today ...
/ Was bush hogging today ... #21
sounds like a petcock broke. if the core stayed inthe rad, try to back it out, then hit tsc for a new one.. or a plug for the time beaing.
soundguy
ya it was just the drain valve (not terribly protected) ... i didnt have any tube to join the 2 pieces for the time being so i had to leave it out in the field for the night .. dealer gave me the bit for free (couldnt imagine it would be all that expensive)
one thing i learned is that even though it looks like a small leak, check both the rad and the overflow tank ... not just the over flow ... i guess a bit of syphon action was all it took to drain 2L of fluid over night
/ Was bush hogging today ... #23
yep.. can't play around with engine coolant... gotta fix that immediatly..
soundguy
/ Was bush hogging today ... #24
G'day valuable lesson learnt about the coolant I always tell my customers to check the radiator periodically as well as the expansion bottle as you can have a leak and a bad rad cap and it may not allow the fluid to go into the rad. Have seen it more than once, and usually when it is too late
Jon
/ Was bush hogging today ... #25
At least your radiator drain is easy to get at. Mine needs a child-sized hand to reach.
When I used to mow in heavy brush alot, I went to straight pins with no loop, but they did have a hole in them for a hairpin.. I installed key ring loops in the pins instead. never lost another, and still prety easy to remove..
soundguy
McMaster-Carr calls them 'cotter-rings' and you can get them individually at Deere dealers; part number M84180. They're just as secure as key-rings without the hassle of getting them open.
/ Was bush hogging today ... #26
I don't particularly have any problem with key rings?
soundguy
/ Was bush hogging today ... #31
In my experience, the cotter ring is the first thing to get destroyed when working in brush. I change them out, quickly. :)
/ Was bush hogging today ... #32
Pictures please gentlemen. Key-ring vs Cotter-ring.
They are just a wire bent in a loop more than 360 degrees.
Google "cotter ring" or go to Mcmaster.com for a search to see pics.
/ Was bush hogging today ... #33
i have something similar to that on the lower arms ... except they have an extra turn and the bit that goes in the middle there straightens out and goes all the way across
/ Was bush hogging today ... #36
After loosing the stock ones, then the lock ones, I now use lock wire in addition to the lock rings; especially on the pins you don't ever remove in the field. That and I still carry a variety of pins with me.
/ Was bush hogging today ... #37
and that's the ansewr.. :) use a good pin.. and carry some backups! and get in the habbit of checking now and then.. or get a good feel for your machine so you know when it is riding wrong..
soundguy
/ Was bush hogging today ... #38
I check everything in the morning, I walk around check for grease on the bottom of the bushhog (leaking output seal) and my 3 pt linkage.
It's a matter of getting used too, better to catch things early.
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2018 KENWORTH T680 (INOPERABLE) (A65643)
2018 KENWORTH T680...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2022 TRACKER OFFROAD 4-WHEELER (A65643)
2022 TRACKER...
