shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,245
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Good job CR.
Glad you helped the fellow out.
1. How old is it? 1,200 hrs could be a 2014 or 2020.
2. How did it get a hole in the tube? And where in the tube?
1. I have owned it for two years - Bought it new
2. Dealer says it was in a small tube beneath the engine. Not sure what the tube function is. I assume some sort of return or sensing tube. No idea how it was caused. Could have been a stick hitting it.
Thanks
I do not disagree with you completely. I also understand that most engines work on this premise. However, I do not know a single person that opens their hood on a car or tractor and checks the radiator for fluid prior to operating. If the fluid all leaked out while parked, how would anyone know. We always checked fluids, oil, radiator reservoir etc regularly. No obvious sign of a problem
Actually it's a catch 22 on the manufactures side, if they tell you to check the fluid level by removing the radiator cap, radiators can remain hot for a long time - if the consumer checks it and it's hot we all know what happens - sorta like the individual that got burnt from coffee and sued / won because she was not told it was "that hot" - to prevent this manufactures on most liquid cooled combustion engines stared directing the consumer to check the fluid via the plastic tank - may not be the right way but it's the liability way - so in essence right or wrong OP may have a case.....I have seen countless tractors from all different brands come in with a full overflow tank and an empty radiator! They are set up to keep coolant from hitting the ground in an overheat situation. It's really a overflow catch not a real coolant reservoir. If you don't open the actual radiator cap a person has zero idea what's really going on.
Thanks
I agree on that lawsuit, McDonnalds paid huge to try & discredit her in the court of public opinion after the fact. That lawsuit was very just due to their repeated negligence.I wish people would stop misconstruing that McDonald's case, as it wasn't as cut and dried as people like to make it seem. She received 3rd degree burns, and originally just asked McDonald's to help with the hospital bills. It wasn't until after they refused that she contacted a lawyer, and the rest is history.
Or perhaps I should say that the rest is an urban legend.
