Warnings on new Kubota
/ Warnings on new Kubota #41
Tractors aren't designed to take on dates--They're made to work. Diesel engines were designed to work and generally at its peak power curve. That translates to PTO speed. If you're not running the engine at that speed, you're driving your tractor to a quick death.
/ Warnings on new Kubota #42
idk around here date night is usually hard work on the land together lol
/ Warnings on new Kubota #43
My old kioti has rpm range for pto on the gauge if i dont have it in that range my oil pressure light comes on also if im using my pipe/cable burying attatchment,no pto,it will come on if i dont have the rpm's up and if idling when i get off i always,always raise the rpms or it will tend to get hot with the oil light on,maybe just my situation
Low oil pressure lights are not good. You say "old Kioti" but you don't say HOW old or how many hours. Low oil pressure can be caused by many things, low oil quantity, blocked oil channels, worn rod bearings, weak oil pump. etc.
It is NOT NORMAL to see this warning, have it looked at before you have to buy a new engine.
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
UNUSED RAYTREE RTSG30-30" HYD STUMP GRINDER (A60432)
UNUSED RAYTREE...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
John Deere S350 (A60462)
John Deere S350...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
