Warning lights on while running and do not go out
   / Warning lights on while running and do not go out #11
I would pull the alternator off and have it tested. You should have a higher reading than just battery voltage when checked at the alternator with the engine running.
   / Warning lights on while running and do not go out #12
Second set of readings 9.24
Probed battery with meter 12.8 volts. Probed battery when running 12.55 volts.
Probed alternator while running 12.55 volts.
Still unsure as to what it means. Do I have a bad alternator or should I be looking for a short?
Thanks,
pathunt
It means your alternator is not charging. Read Post #7.
Dear TBN's
Success.
Checked wiring at dash and guages, rebuilt grommets that keep dash from vibrating, secured wiring from vibrating at connections near alternator. Bought & installed new alternator. Put everything back with no leftover parts. Started it up - battery charging at 14.2 - just in time for grandchildren's hayride.
Thanks again.
Pathunt
   / Warning lights on while running and do not go out #14
Thanks for reporting the 'Fix'.
   / Warning lights on while running and do not go out #15
"Thanks for reporting the 'Fix'."
Ditto. Always nice to hear "the rest of the story."
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2015 Isuzu NRR John Bean 700 Sewer Jetter Vacuum Truck (A49461)
2015 Isuzu NRR...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
