Warning lights on while running and do not go out
   / Warning lights on while running and do not go out #1
pathunt
Adair County, Northeast Oklahoma
Massey-Ferguson 251XE
Dear TBN's
Today's puzzle: Massey-Ferguson 251 Problem: 3 Lights in dash come on and will not go out. Battery charge warning light comes on. Engine oil pressure warning light comes on. Transmission oil pressure warning light comes on. Tractor runs with all three lights on.
Belt to alternator is tight and is tensioned on fan pulley.
Transmission shows fluid up to XX mark on dipstick (full).
Battery appears to be sound.
Front lights work. Rear lights work. Turn signals work. Flasher works.
Checked fuses in cavity below steering wheel. All appear to be ok.
Where would I start to get the lights to go off and fix what might be wrong?
9.19
a. Checked battery ground. Cleaned the Ground to the frame and surprising amount of crud around battery. Cleaned off radiator. Started tractor. Lights still on.
b. Unplugged warning light leads (lights went out) and plugged them back in - lights still on.
c. Tachometer has lights on from the dash, but DOES NOT WORK.
d. In process of recharging battery - running it at idle did not charge it.
More tomorrow....
Thanks,
pathunt
9.20 Evidently tachometer is connected to alternator in some way. Will have to take rear shroud off and start checking wires.
   / Warning lights on while running and do not go out #3
Bad alternator can give such symptoms.
   / Warning lights on while running and do not go out #4
MF240, battery light came on and stayed on like yours. Trouble was tracked to a faulty alternator, it was only delivering a weak charge, 8 or 9 volts instead of 12 volts.
Thanks redman and agvg...and rest of TBN -
I have the shroud, top over the fuel tank, side screen off front of alternator and panels off the tractor. I can see the wiring and alternator wiring and will be able to check it with a multimeter. That was it for the morning. Other stuff to do today - appreciate your suggestions and encouragement.
Will post what I find out on Saturday.
pathunt
Starkiller Hollow, Oklahoma
Here is what I found out -
Probed battery with meter – 12.87 volts. Probed when running – 12.53 volts.
Probed alternator while running – 12.53 volts. Small red wire – 1.21 volts.
Started tractor and took off negative to battery– tractor stopped.
Have to think about what it means. Thanks.
pathunt
   / Warning lights on while running and do not go out #7
Never test a alternator by disconnecting the battery while its running, it can kill it in an instant.
You have a dead alternator, does it have an replaceable regulator?
   / Warning lights on while running and do not go out #8
The tach is probably connected to the W output.
Agvg: I found the wiring diagram.
It is connected.
There has been a suggestion that I take an 8 ga. wire and connect it between the alternator and the hot lead on the starter. That is supposed to bypass the wiring harness. Would this work?
Thanks.
pathunt
Probed battery with meter 12.87 volts. Probed when running 12.53 volts.
Probed alternator while running 12.53 volts. Small red wire 1.21 volts.
Started tractor and took off negative to battery tractor stopped.
pathunt
Second set of readings 9.24
Probed battery with meter 12.8 volts. Probed battery when running 12.55 volts.
Probed alternator while running 12.55 volts.
Still unsure as to what it means. Do I have a bad alternator or should I be looking for a short?
Thanks,
pathunt
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 Caterpillars 299D2 XHP SKIDSTEER (A51242)
2019 Caterpillars...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
1274 (A50490)
1274 (A50490)
