Warm Up / Cool Down? ? ?
/ Warm Up / Cool Down? ? ? #11
You need to give enough time to circulate the oil on startup and that should take only seconds, I usually give it about 15 seconds to a minute at most to stabilize the oil pressure and then use it gently for a few minutes, mostly driving it to where I need to use it, before putting it to hard work. Shutdown whether you have a turbo or not it should be allowed to idle for about a minute before shutting it off, to allow it to idle for 5 minutes is just a waste of fuel and time.
Do you let your car idle for 5 minutes before driving it or shutting it down? Tractor is no different than your car or truck. However ALL vehicles, gas or diesel, with a turbo need to idle for at least a minute before shutdown.
/ Warm Up / Cool Down? ? ? #12
Been driving cars and pickups for 50 years and tractors now for 16 years after driving them early in life. Just start and go gently. Shut down when stopped. Have never had an engine failure. (Actually, never a clutch failure either except for the time we allowed a kid to use our Fiat 1100)
/ Warm Up / Cool Down? ? ? #13
The first farm tractor we had with a turbo was an Oliver 1955 back in the early 70’s. On the dash near the shut down pull were instructions to idle at least three minutes to allow the turbo to cool down. You could watch the engine temperature drop and the old Oliver never had an engine or turbo issue. I do it with my MX5100 and diesel Sprinter RV too.
/ Warm Up / Cool Down? ? ? #14
I go by the outside temp. In warmer weather the warm up time I give it is maybe a minute, colder weather about the same I just go slow and easy for a few minutes and gradually bump the throttle up.
Cool down? Usually not, it depends on what I was doing. Mowing and working the tractor hard, a couple of minutes. Driving the tractor around or end loader work, usually none because the last thing I do is drive to the garage and I figure it cools down then.
With a turbo and the example you give, disc work in a field, the turbo probably needed cool down time. If you normally are driving back to your shop for a minute or two, that probably gets most of the cool down time.
/ Warm Up / Cool Down? ? ? #15
My tractor lives in a barn, and I sometimes pull it out just seconds after starting, because it gets smoky in there! But this means lifting the ballast box (if it's on) and the loader. I always wonder if this is any harder on it.
Also -- do folks let the machine warm up at low or high engine RPMs? I had a car with an automatic transmission that kept RPMs high by staying in low gears until the blue "cold" indicator light went out. Think I remember reading somewhere that low RPMs are harder on the engine when it's not warm yet.
/ Warm Up / Cool Down? ? ? #16
My Kioti manual says to warm up the engine at "the medium speed" not idle. I take this as 1000 to 1200 RPMs. I always wait until the temp gauge clears the "C" on the gauge before utilizing the tractor for work. Same on shutdown, I wait a couple of minutes after performing work.
/ Warm Up / Cool Down? ? ? #17
I start it and let it idle at about 1300 rpm until the engine starts running smoothly (maybe 15 seconds ish depending how cold it is). Then I bump it up to a little over 1500 and start to use it gently for the first minute or two. Anything more is just burning fuel for no reason IMO.
If you have a turbo you don't need to let it idle at the end of the day unless you are working it hard and are going to park it right where you are working it. Driving it back to the garage easily is more than enough. Maybe if it was a very hot day I could see letting it idle to cool down some but it's only going to cool so much.
/ Warm Up / Cool Down? ? ? #18
I really doubt factories idle turbo diesels when test running. Turn the key on right to max throttle. Otherwise I slow - medium idle for a minute or two unless really cold, then longer. When I shut down after working hard, maybe 3-4 minutes. But normally I putz for a half mile to the barn then park and shut down.
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2013 Toyota Corolla Sedan (A59231)
2013 Toyota...
2023 GMC Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC Seirra...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
