Want quick hitch but am confused by choices. Which one?
   / Want quick hitch but am confused by choices. Which one? #51
Here is a photo showing the left 3pt attachment. The tan part is the Landpride blade, the black is the Speeco QH. Notice there is a flange on the QH on both sides of the latching member. The right flange is wedged up against the Landpride's bracket. This might be hard to see because the right flange is in the shadow. A photo of the right 3pt attachment would show that side is just as tight. Landpride advertises this as "QH Compatible" and it would be compatible with this QH if the QH didn't have those flanges.
View attachment 374650View attachment 374650
are you sure those aren't the same picture?
   / Want quick hitch but am confused by choices. Which one? #52
Shame that a standard is not really a standard. Perhaps your Land Pride blade is QH compatible with a Land Pride QH. My Land Pride rake and tiller fit both of my Land Pride Cat 1 QHs. Some of my other attachments are a tight fit similar to your situation but they did fit without modification. I did put bushings on all my attachments, they are pretty cheap at TSC, but they do rust and cause a tight fit. I have to use a little WD40 and tap with a hammer to get the QH to let go occasionally if the attachment stays on for long.
   / Want quick hitch but am confused by choices. Which one? #53
94BULLITT--spectacular videos and boy doesn't that tell the story. The imatch looks really well made. Thank you for posting those videos.
I am glad you found them helpful.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
Friesen 220 Seed Tender (A50514)
Friesen 220 Seed...
2017 CATERPILLAR 305.5E2 CR EXCAVATOR (A51242)
2017 CATERPILLAR...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
