LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,252
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I have a manual bead buster;
Esco Dual Agricultural Tractor Manual Tire Bead Breaker – All Tire Supply
And a couple of 30 inch tire spoons.
We break down our tires with the rims still mounted on the tractors,
jack it up to get the weight of the tire, break the bead outside and inside.
Most tires with have a small section of the sidewall next to the bead that is shaped for a bead breaker it's kind of a notch,
that's were we start breaking the bead then just work your way around the tire.
Lots of soapy water and lots of work.
Bring the outer bead off the rim slide the tire halfway off, pull the tube out,
slide the tire over to the outside of the rim and bar it off,
raising and lowering your tractor as you go to make it easier.
Putting them back on hook the top of the tire bead over the rim raise the tractor use your irons if needed to get the inside tire bead on the rim,
install your tube, shove everything as far in as possible and carefully iron your outside bead onto the rim being carefull not to pinch your tube with the tire or irons.
Otherwise you will get more practice removing the tube and patching it and reinstalling it.
You could also have a mobile tire repair unit come out pump out the calcium and pull the tires and tubes off the rims.
Set them aside while you spend a few days wire brushing priming and painting your wheel then you could have them come back out and remount them.
