want down force
/ want down force #1
dt duncan
col. hgts. va.
ford/jd
i have a jd37 loader on my 1020; iknow that i need to replace the cylnders for the loader up/dn, i'm not sure the GRESEN 2712 two spool can be piped to allow me to have force down on my bucket?
/ want down force #2
If the cyl on your loader are DA cyl, then you can have down force.
Do you have float?
/ want down force #3
Do you have float?
After finding some pictures of the JD loader, it appears the cyl is an SA cyl.
You could perhaps change out the cyl for a DA cyl and a new joystick valve and have regen, float, and down force.
http://www.farmphoto.com/thread.aspx?mid=881518
Your hyd system is also closed center, so here is a joystick valve that I would recommend.
http://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
There is a closed center adapter for this valve, on the right side of the page.
/ want down force
J.J.,
Thanks for your reply, you are correct on my JD37 loader has single action cylinders. The bucket has a dual action cylinder. I know I will have to replace the two single action cylinders with the two dual action cylinders.
Since,the GRESEN 2712 control valves one lever works my dual action bucket, can the side that works the single action cylinder now be replumbed or repiped to allow for downforce operation on the dual action cylinder? I have worked around hydraulics but, I need help with definitions such as: floats and pb.
Thank you for the info hope this note find you and your family in good health. D.T. Duncan
/ want down force #5
Show me a picture of the valve work ports.
I suspect one of the work ports is plugged.
http://www.tractorbynet.com/forums/...716-gresen-2712-control-valve-power-pic-1.jpg
Does your valve look like the one in the picture in the link?
I believe the large hex nut is the Closed center plug.
You don't need to worry about PB as your valve is configured for closed center .
All closed center valves are in parallel.
