Walker's F Series Thread
   / Walker's F Series Thread
I mowed roughly 2 acres last night, what a dream!! The tires were over-inflated, I let some air out and it made a big difference in the ride. It follows the contours very well and leaves a great cut.
I put together a short video of the F series:
Today I ordered deck castor pins and bushings, will be in next week. $175 total from local dealer, a little higher than Messicks but trying to stay local.
I took the seat off to clean the slide mechanism, was bound up bad.
   / Walker's F Series Thread #13
My seat cushion is shot. I don’t even want to ask what a new one costs.
   / Walker's F Series Thread #14
Not sure but I doubt original replacement seat or cushion is available.
My seat has definitely seen better days,,,,, I'm not sure if I'll splurge one a new one or not, but I'm definitely adding rubber isolators, they should be here within a week.
The water pump is leaking some coolant from the shaft area. So I'm guessing it is the weep hole. The one on it is bare aluminum so I don't believe it is factory, I think factory ones would be all gray in color, I'll have to look at my BX to be sure.
Another must-do item is to replace the seal around the air inlet screen and adjust the latch so the hood closes evenly on each side, there is little room for error or it sucks in around the seals.
   / Walker's F Series Thread #16
It's getting close to when I'll have to get my old F2000 and it's 72" side discharge deck going again.
   / Walker's F Series Thread #17
We’ve already mowed twice down here.
I built the seat iso-mounts in 3d... will be several parts to cut out.
Hopefully the second pic makes my plan more apparent. The black boxes are the black plastic control consoles, the orange is the floorboard/fenders/seat mount location. The round things are the rubber iso-mounts, Exmark part #109-9034. They allow .5" vertical and .75" lateral movement. The sloped plate is what the seat rails will sit on. The seat will sit just over an inch taller than stock after this modification.
Here is a stock photo showing the same angle:
   / Walker's F Series Thread #19
I used rubber iso mounts on my ZD331. They were just common pipe plugs from a hardware store. Worked great.
I would do like to do them for my F3680, too.
   / Walker's F Series Thread #20
Looks like a good plan!
Those Exmark rubber mounts are about $60 each, ouch...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A51039)
Quick Attach Skid...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A51039)
2020 Massey...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
