wahsboarding driveway
/ wahsboarding driveway #1
94BULLITT
Super Member
USA
yes
What causes a driveway to washboard?
/ wahsboarding driveway #3
Rain on off camber areas and vehicles accelerating or slowing from/to a choke point.
/ wahsboarding driveway #4
Are you referring to the "washboard" effect on straight, flat semi-soft surfaces or hilly gravel lanes etc?
[just my observations and experience]
the former is usually caused by the dynamic action of a vehicle (on tires) and speed where the latter is often caused by run-off creating one or more minor "dips" that eventually induces a rhythm of a moving vehicle that compounds and expands the issue
Thanks for all of the fast replies.
Thanks for the link. It has been dry here. I thought that speed was a factor and the link said you need to go 3mph or less. I have some people who fly in my drive way.
I am not exactly sure about the what you mean about rain on of camber area's. Do you mean water washing across?
It is a straight portion. I have not seen water running on that portion of the driveway.
/ wahsboarding driveway #6
In my limited experience vehicles cause this. You could install 21a pug mill stone compact it properly and solve this for a while but it will come back. Surface treating or paving are two ways to solve the problem
What do you mean by surface treating?
/ wahsboarding driveway #8
Prime and double seal or tar and gravel. There are three coats involved. Tar is crs-2 applied at rates of .30 gal per square yard, .35 gal per square yard, final coat .35 gal psy. Stone at30 lbs of 68s,35 lbs of 78s, 35 lbs of # 8 s. this would solve wash boarding
Sounds like that would definately solve washboarding.
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
2011 JACK  130BBL (A63569)
2011 JACK 130BBL...
FRONT MOUNT TANK (DAMAGED) (A63290)
FRONT MOUNT TANK...
