Gravel Driveway using Grid products to reduce washout
   / Gravel Driveway using Grid products to reduce washout #21
Yes. As someone who has ridden trails for a long time and made some miles of them on my own. You know you’re riding and older trail if it has water bars. The new trails are designed with smooth rolling dips, the trail holds up better and I think it’s more enjoyable also.
Unfortunately with driveways you don’t always have freedom to do the dips and don’t forget straight down is less distance and less gravel;)
We use water bars on logging skid trails and temporary roads that are intended to be closed. Rolling dips are used for open, drivable roads.
Folks, thanks for all the replies and I apologize for not being more engaged on the thread I started. To fill in a bit more detail my driveway is a quarter Mile long with about 200' being on a steep incline with a curve. I do feel it could benefit from cutting my ditches a bit deeper/more defined, but I am limited in doing so on the uphill side as ATT laid fiber on that side. I am WAAAY farther than ATT's standard distance so I am very unwilling to give them an excuse not to replace the fiber (frankly I'm not sure why they laid it in the first place). THe Crusher run was laid on thick when the drive was built 5 years ago, but with any hard rain it gets rutted to where a box blading is necessary. I though about the grid stuff on the hill and am also thinking about the Highway guard rail channel drain idea. The other Idea I have is scraping a berm of crusher run on the uphil side of the drive to create a better ditch (aka building up versus digging down). Thoughts?
   / Gravel Driveway using Grid products to reduce washout #23
Using crusher run to avoid digging is a good idea when you already have washing and dont want to make it worse by loosening the existing material.
   / Gravel Driveway using Grid products to reduce washout #24
Perhaps building the road surface up with a larger heavier rock, then topping with crusher run.
   / Gravel Driveway using Grid products to reduce washout #25
I haven’t added larger rock on top of an existing gravel road to know what it will do. I have put down larger rock on dirt on a hillside drive as base. It seems to be more resistant to washing out than smaller rock or crusher run.
If you posted a picture, that would help the rest of us see what you are dealing with.
   / Gravel Driveway using Grid products to reduce washout #26
Looking at this another way. What is the cost for a 4 inch thick concrete slab at 9 feet wide based on concrete material only.
If your going to excavate 12 inches to build a base for the plastic grid, why not excavate 8 inches and put in 4 inch gravel base and then add 4 inch wire reinforced concrete?
To build the plastic grid surface requires 12 inch deep stone base at 9 wide by 3 running feet of driveway is one cubic yard of stone, at a delivered cost of $40 ( approx) and add the plastic grid which is either $2.89 of $4.38 per square foot according to their web site. Larger quantities are quoted.
Presume concrete price is $150 a yard. A 4 inch by 9 foot wide by 9 running feet slab of concrete is a cubic yard, so $150 divided by 81 square feet yields a price per square foot of $1.85 for material.
The concrete will require a 4 inch base at approx cost of $0.50 per square foot
Sum of concrete base plus concrete slab per square foot is $2.15 or less than either one of the grid costs for grid only.
I've not included labor or machine time cost for either since presumed roughly equal so a wash.
Am I missing anything?
I wish, locally gravel is $65/yd and concrete is at $220/yd. One of the drivers told me last week they’re talking 300 by summer. :eek: 80 lb bags are 5.50 each x 45 = 247.50
To the OP, there are a few geo grid products out there. Some come in rolls for large format jobs
   / Gravel Driveway using Grid products to reduce washout #27
At $65/yard, I would Not do a gravel and geogrid, over $220/yard concrete. Just materials alone, that grid isn't cheap, and concrete, typical is 6", but for residential, I wouldn't feel bad about doing 5", or maybe a True 4" (not 3.5") with wire. The gravel and grid, the grid originally linked, i belive called for a base of 6" of rock, then grid and 4" of rock. So, I think our OP said 300ftx12×0.5=1800cf=67 cy concrete=$14,740
300x12x0.8333=3000 cf=111 cy=$7215 in rock, plus atleast $3600 in grid=$10,815.
We can decrease our costs in several ways; drop 12 ft drive to 10 ft or even as low as 9 ft; we can do 2 each, 30" wide tire tracks; we can go to 4 or 5" of concrete; and we can likely get the cost to below the gravel and grid....
   / Gravel Driveway using Grid products to reduce washout #28
Actually, so... I went back and reread your original post, and you installed a good base material originally, pretty thick, and erosion is most of the issue, correct?
Double Application Chip Seal, you can likely have the entire drive double application chip sealed, all 1360LF, 12 ft width, around $7500,
   / Gravel Driveway using Grid products to reduce washout #29
My answer was in two parts, hence the separation. I was not suggesting what he should do. I was just letting him know there are different geo grid options available.
I would not advocate for a 4” or less concrete drive.
My area there is no one that does tar and chip.
IMO, the OP has a drainage issue allowing the sub base to move. IME, until that is corrected anything applied on top will be just a Band-Aid.
Again IMO, I would hire a civil engineer to see what the source problem is. This may very well involve moving the crusher run, regrading, adding a geo product and moving the crusher run back. The OP could also do some soil sampling and moisture testing to try and resolve how much water and why/where before spending a bunch of money on a Band-Aid. Of course they would have to find a lab that could help.
   / Gravel Driveway using Grid products to reduce washout #30
So, there can be a couple issues. Forgive me, these driveway thread details blend together... So, we have an uphill and down hill side of the drive. We have a fiber along the uphill side, preventing a meaningful ditch.
So, is the driveway tilled towards the hill, and the water captures there, and follows the drive down hill on the hill side? Or does the water sheet flow from the hill over our drive to the downhill side? Are there any hill side seeps, with water leaking out?
If the water is captured on the hill side, and drive is tilted that way, do you have cross drains to get it from the ditch to the downside of the hill?
Is our erosion straight line, just water getting on the road and flowing With the road, and building up speed? Is the erosion on the hill side-fiber side ditch, or in the down hill, embankment side? Those are 3 different problems, and 3 different solutions.
Sorry for having pic in on post and text in the next, I've never posted pics before. In the first pic to the far left of the dog (left side of gravel) is where the worst of the washout begins. water flows down the driveway from there creating ruts. The second and third pics show where I have no ditch, washout is not as bad there as it is farther down, The last pic is downhill looking up. The worst of the washout would be on the right in pic4 as the water is flowing down the driveway. I feel like the problem is mostly water that comes straight down the driveway, but it is fed by the lack of ditch uphill.
Please note these pics do not show the actual washout as I box bladed it after the last heavy rain...
   / Gravel Driveway using Grid products to reduce washout #33
Looking at your rock, it doesn't look like you have fines mixed in with the larger rocks. How thick is the rock? The fines will lock the rock together and make it look almost solid. Your road looks like loose rock. If it's not thick enough, it will never lock together.
Were I live in East Texas, 4 inches is the minimum for road base rock to lock together when compacted. When the County builds roads, they put down at least a foot of rock and roll it with vibratory compactors.
If the rock does not lock together, it will wash away. Once it's compacted, the worse thing you can do to a gravel road is to disturb the rock. Dragging it, grading it, or doing anything to it will weaken it. Potholes should be dug up, filled and compacted with a little damage to the surrounding rock as possible.
If you do not have enough rock in place, it will never stop eroding.
Interesting, it was professionally laid and compacted and was plenty thick to start. That being said I've box bladed it 100 times since then. It did erode first before my first box blading.
I wonder if it makes sense to put down some gravel fines to help lock the loose gravel at this point.
   / Gravel Driveway using Grid products to reduce washout #35
It looks like atleast the top layer is loose gravel. That can be caused by the box blading to fill the erosion though.
Some of that loose could be caused by a couple things. It looks kinda narrow, using the dog for scale, it looks 3.5 dogs wide, and it probably should have been a full 4 dogs wide. I'm kinda joking, it looks 9-10 ft wide, and it is possible that the vehicle traffic is pushing everything outward.
   / Gravel Driveway using Grid products to reduce washout #36
IMO, that would be a waste of money at this time. Fixing the water/drainage issues should be your first priority. in the first picture, there appears to be little to no drainage away from the graveled area.
   / Gravel Driveway using Grid products to reduce washout #37
In your last picture is your fiber buried on the left side? Is it from this left side that water is not being shed from the driveway and running down its length? My initial impression is you need a more aggressive crown to shed the water off the driveway as soon as you can and then you need a ditch or a swale to divert it away.
In the last picture the fiber is on the right. There is a decent ditch at that point but the water from uphill is moving down the driveway bypassing the ditch. That picture is where the worst of the erosion happens.
   / Gravel Driveway using Grid products to reduce washout #39
Near here we have the Kettle Moraine recreational area. It's basically highly erodable glacial till sand and gravel with forest roads and trails in and around all the hills. 30yrs ago they experimented with all sorts of erosion control. Dozens of kinds of buried plastic wood and metal mesh, timbers, buried canvas diverters, crushed stone, spray on hardeners etc. Not a one worked. When it was finally realized that velocity and volume overruled all of it did they finally come up with a plan. All the contraptions were removed. Water was kept from gaining momentum. Roads were crowned, trails were tilted to shed water sideways and dispersed. Curves had a reverse camber to keep the inside corner from pooling. Those going straight up hills were rerouted or rebuilt.
   / Gravel Driveway using Grid products to reduce washout #40
Beautiful property. Like others, I'd suggest more crown to your road and doing what you can all along the slope to divert it off the road. You don't want it to run a long way downhill on your road because it will washout.
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
2014 CATERPILLAR...
John Deere 853 20ft Corn Head (A56438)
John Deere 853...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
