Voltage Regulator-Rectifier
/ Voltage Regulator-Rectifier #1
JWR
Elite Member
So MD / WV
MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
B&S engine on model 1232 rear engine rider Gravely. I'm not where the machine is but once a month and try to get parts lined up for each visit.
The engine data from a photo says Family: YBSXS.5012VP 274826. I do not have the Model, type, and code from the engine at the moment.
The part is square with a small bolt in the center of it and shown in this photo with 2 wires attached -- a red and a yellow. Can't tell if it is the 5 amp or 9 amp flavor as my documentation says they made both.
Anyone have the same equipment or replaced one of these ?
/ Voltage Regulator-Rectifier #4
Great help. Thank you. How can you tell that this one is the right one compared the one that looks the same on Amazon and is $14.03 ? The price is not the biggest deal, I just can't figure out how you tell.
The $14 dollar one should also work, but is Chinese aftermarket, thus the difference in price. This ones $14.17 and has 4 5 star reviews. Good start, but low sample pool..: Amazon.com : Voltage Regulator for Briggs & Stratton 79436, 691188, 491546 : Patio, Lawn & Garden
Personally, since there is no real way to actually tell who makes them, I would be inclined to order up the $14.17 one and give it a go.
/ Voltage Regulator-Rectifier #5
I looked at those posted regulators and my impression is that they are simple full wave bridges wired so as they use the chassis as the neg or ground. As such those bridges are as inexpensive as less than $1.00 from many sources. Would be worth a try IMO.
/ Voltage Regulator-Rectifier #6
Pretty sure theres some kind of regulating circuit in there too..
12 Ton Hydraulic Jack (A64127)
12 Ton Hydraulic...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
1998 International 9400 (A64127)
1998 International...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
Concrete Mixer (A66408)
Concrete Mixer...
