Vinyl Cab Enclosures
   / Vinyl Cab Enclosures #1
ctcrtaja
What does everyone think about Vinyl Cab Enclosures.
Pros and Cons...
I am trying to decide between a factory cab with heat and a/c VS the Vinyl Cab.
Can you have heat in a vinyl cab?
Thanks for all you opinions!
   / Vinyl Cab Enclosures #2
If the tractor you are looking at has a factory cab option, and you can swing it, get the factory cab, no comparison IMHO.
But, if you want to keep dry and warm, but enjoy the fresh air during the three other seasons, get the vinyl cab. A factory cab will add $6K to the price of a CUT.
You should go kick some tires, sit in a few, and see how you feel.
Hope I did not confuse you??
   / Vinyl Cab Enclosures #3
I've found that a golf cart cover jury-rigged over my tuff top works well and is very cost effective
Thanks for the replies.
So I vinyl cover will keep you warm as well in the winter?
Thanks
   / Vinyl Cab Enclosures #5
Factory cabs are in a class of their own and worth every penny they cost if you can get one. If they have air and heat they are year round confort zones. A vinyl cab will be a windbreak.I am always glad when the weather allows removal.
   / Vinyl Cab Enclosures #6
mine keeps me pretty warm...heat from the engine and, depending, some solar uptake...you could always install a heater cut into your radiator lines.
Also available is a heated seat pad that doesn't draw much juice.
wind is your enemy and you can find "windbreaks" for some tractors...topless but shield you from the wind and have proven effective through the years.
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
NORTHERN 3P-100 AG MIST SPRAYER (A51247)
NORTHERN 3P-100 AG...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
2023 LMC M40018 LOT IDENTIFIER 163 (A53084)
2023 LMC M40018...
