Vinyl Cab Enclosures
   / Vinyl Cab Enclosures #1
ctcrtaja
What does everyone think about Vinyl Cab Enclosures.
Pros and Cons...
I am trying to decide between a factory cab with heat and a/c VS the Vinyl Cab.
Can you have heat in a vinyl cab?
Thanks for all you opinions!
   / Vinyl Cab Enclosures #2
If the tractor you are looking at has a factory cab option, and you can swing it, get the factory cab, no comparison IMHO.
But, if you want to keep dry and warm, but enjoy the fresh air during the three other seasons, get the vinyl cab. A factory cab will add $6K to the price of a CUT.
You should go kick some tires, sit in a few, and see how you feel.
Hope I did not confuse you??
   / Vinyl Cab Enclosures #3
I've found that a golf cart cover jury-rigged over my tuff top works well and is very cost effective
Thanks for the replies.
So I vinyl cover will keep you warm as well in the winter?
Thanks
   / Vinyl Cab Enclosures #5
Factory cabs are in a class of their own and worth every penny they cost if you can get one. If they have air and heat they are year round confort zones. A vinyl cab will be a windbreak.I am always glad when the weather allows removal.
   / Vinyl Cab Enclosures #6
mine keeps me pretty warm...heat from the engine and, depending, some solar uptake...you could always install a heater cut into your radiator lines.
Also available is a heated seat pad that doesn't draw much juice.
wind is your enemy and you can find "windbreaks" for some tractors...topless but shield you from the wind and have proven effective through the years.
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
Kawasaki NR (A50324)
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
