Vines/briars getting caught in tiller
   / Vines/briars getting caught in tiller #1
thunder86
Southern Indiana
Bobcat ct4045
So I’ve got an overgrown field I used my cutter on and tried to till it only getting a couple passes and now having to stop and spend hours digging out vines/briars/grasses.
So I can cut it lower, in future I can try and cut it at 3 hights to break things down better. But most the stuff just pushes over and lays flat especially the vines.
I do have a box blade with rip teeth that may grab this junk and get it outa the way before I till.
My main questions are what is the best way to get this junk off my tiller and secondly does this same issue happen with a disc? Seems like a disc would just cut a vine before it wrapped up on it. Thanks.
   / Vines/briars getting caught in tiller #2
It can happen with a disk, when material is like that I just straighten my disks, weight it down and cross hatch it a few time to chop as much as I can. Nice part about disks is when it does wrap it's really easy to get off with a saw and a careful hand, brush hogs and tillers when they get wrapped seem to love to cram stuff right up against bushings and make themselves a pain in general to get cleaned/freed up.
   / Vines/briars getting caught in tiller #3
After mowing, best to come back with a notched disc harrow. a dual gang would do awesome in your application. Even if you can rent or barrow one for the job the tiller would be better off in the finish passes.
The down side is, vines are very troublesome. Even after discing them, you go from a hand full to hundreds of little ones that then regrow. Constant mowing tends to rid them over a few years.
What do you mean dual gang? I may I have to cut what I want in food plots in the winter months and till early spring while everything is dead still.
   / Vines/briars getting caught in tiller #5
dual gang - - -
single gang
(not a big fan of this setup)
Mine is notched dual gang double row (see below). Thus, it's ideal for areas with plenty of woods nearby or areas that were recently logged.
It's been a great working piece of equipment for root busting and pulling the rocks out from under the soil to the top. The gangs are also adjustable to the right attack angle too. Over 3,000 trees logged at my place. This tool has been the best thing ever to get the soil back to full pasture.
   / Vines/briars getting caught in tiller #7
When the tiller gets plugged, a tile knife speeds the cleaning process along.
Beat me to it! I bought a couple of cheap linoleum knives at HF and jammed one into a piece of conduit so I can reach the center from either side. It stays on the tiller held by a bungie cord. Essential!
But mowing first is sufficient for grass alone. Blackberry vines? Good luck.
   / Vines/briars getting caught in tiller #8
if i remember correctly, i got the idea from you. THANKS!
   / Vines/briars getting caught in tiller #9
Can you run the disk or tiller around the outside edge to create a fire stop and then burn the field? I am not sure if this would work for your application.
   / Vines/briars getting caught in tiller #10
I’ve got a Baltic and Howard tillers that have curved self cleaning tines. Can till 6’ Johnson grass, blackberries or deep in the woods. Have even tilled kudzu. Rarely wrap. See straight tine garden tillers at the farm supply stores wandered how they performed.
Not new. Howard rotovator is probably 60 years old.
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
TMA (A49461)
TMA (A49461)
