Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc...
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc...
Nice auto connect.
Would have liked to have seen that big bush hog doing some cutting of some small trees, maybe on a slope.
Another video shows taking on an 8 inch tree.
Wonder how the Toolcat and the other Bobcat are on slopes. All those videos are on relatively level ground.
Here's smaller trees earlier in this thread, also have tall grass earlier in this thread too. Can't help you with slopes...I live in SE Michigan!
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #52
Very stable.
This is about a 27 degree slope:
New video, got a box blade for the rear utvhitchworks farmboy 3-point hitch. Grading my dirt track.
Finally got around to adding a backup cam (and "dash" cam) to my toolcat. Front cam helps with seeing the front passenger corner of attachments and rear helps backing up and watching the 3 point.
Probably not news to any of you but here's how I control my hydraulic angle non-floating snow plow
It's been a while but made another toolcat video with it plowing about 10" of wet snow on the concrete driveway.
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #57
you have the same issue I find when plowing, I have the V blade and in low speed it moves the snow but never throws it off the side, if I use high speed (rabbit) at 12 to 14 mph it throws good but easily bogs down the motor and does not maintain the speed, I tend to drive thro in low speed with plow in V setup then high speed angled, taking less bite it maintains the speed and throws nicely
Latest video, mowing atv grass trails with brush cutter
I finally did the switch to truck tires, Toyota Tacoma 265/65r17 on 17x7.5 +30mm offset wheels. Fit with no rubbing (i've driven on them loaded off road since and nothing seen even with lifting tires off the ground in ditches).
Full video on the install and findings/learnings
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #60
with the extra height of the tires how does the bucket sit with arms fully down? can you still sit flat on the ground? what about grass cutting?
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
case 370 glass door never installed (A56435)
case 370 glass...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2020 DRAGON ESP...
