very upset update.
   / very upset update. #11
Darin,
If it is a standard shift, it will work but if it is an automatic I don't know. On cars made 20 years or so ago and before you could be going down the road in a higher gear at a higher RPM. Them you would let completely off of the gas peddle. Let the car come to a slow pace by engine compression only, them take it to a high speed and rpm again. By repeating this the excess gas that was drawn into the cylinders, would wash them down and make the rings wear. By making them wear, you would break them in faster. I does take several cycles.
   / very upset update. #12
Oh I see. Thanks for the info.
Darin
   / very upset update. #13
This is pretty similar to the way I was taught.
Accelerate moderately, say from 40 to 60 in high gear.
This helps the rings wear in.
Let off the gas completely, and decelerate back down to 40. This pulls a high vacuum and pulls oil to the rings.
Repeat for about 1 hour. Watch the temp guage and don't overheat.
   / very upset update. #14
i may get some flack here but on the newer cars don't think you need to worry about setting the rings. there a millions of cars bought that people just get in and drive away. the only thing is not to drive at one speed for an extened period. other than that ,don't wory about it.
   / very upset update. #15
I think you're right, Frank; cars ain't what they used to be - - Thank Goodness!/w3tcompact/icons/laugh.gif
   / very upset update. #16
By the time you've taken delivery of that car/truck, those rings are virtually seated. Just drive it - change the oil at 500 miles, then again at 2000 miles, then at regular mfg interval and you'll be fine. Use a good quality oil filter.
When we build an engine, we run it for 20-30 minutes to break the cam in, change the oil, then it's ready for some full throttle pulls on the dyno.
   / very upset update. #17
Good for you. I'm glad Kubota came through. What was that dealer thinking that Kubota does not cover engines?/w3tcompact/icons/mad.gif Anyway try to forget the bad, and get on with using that new tractor /w3tcompact/icons/smile.gif
   / very upset update. #18
Great to hear your problem has finally been resolved to your satisfaction. I know when I had a steering cylinder problem this year and my dealer could not resolve it, Kubota technical service in California was excellent with super fast response!
Glad I bought a unit from a company that respects its customers.
Just to let everbody know, We finally got some snow here. We recieved about 8 in. Christmas Eve and a lot of wind. My tractor ran perfect. I hope all my problems are solved. The block heater is somthing I should have done a long time ago. I would recommend one to everybody.
   / very upset update. #20
Congrats. /w3tcompact/icons/wink.gif
17101 (A55787)
17101 (A55787)
POLY TOTE W/ WIRE CAGE & PALLET (A52708)
POLY TOTE W/ WIRE...
VERMEER BP7000 BALE PROCESSOR (A58216)
VERMEER BP7000...
WAKO FERTILIZER (A58216)
WAKO FERTILIZER...
2106 (A58376)
2106 (A58376)
Yukon Jack Skid Steer Bucket Attachment, 46" W x 48" L, Asset# 70 (DELAYED REMOVAL, CONTACT SITE (A59076)
Yukon Jack Skid...
