very upset update.
   / very upset update. #21
i am an exp. kubota mechanic that actually rebuilds the engines in some rare cases when one wears out and/or breaks, this is how i handle a new start up or rebuild 1 start engine at low rpm 2 let temp start to come up (aluminum and steel and cast iron all expand at different rates) 3 bring rpm up to 1000 ( i should mention that i'm hooked to a dyno, but if you have a bush hog you can hook to that for some load) when 4 when temp is normal i push it wide open , and on the dyno with the read out you can actually see the engine start to make more horspower , run in time is from 30min to 2 hours with around a 20% load. that is how i do it and so far no come backs for any internal problems.....
LAWN AERATOR (A52708)
2011 Ram Pickup Truck (A56858)
2011 Ram Pickup...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
