very upset update.
/ very upset update. #21
i am an exp. kubota mechanic that actually rebuilds the engines in some rare cases when one wears out and/or breaks, this is how i handle a new start up or rebuild 1 start engine at low rpm 2 let temp start to come up (aluminum and steel and cast iron all expand at different rates) 3 bring rpm up to 1000 ( i should mention that i'm hooked to a dyno, but if you have a bush hog you can hook to that for some load) when 4 when temp is normal i push it wide open , and on the dyno with the read out you can actually see the engine start to make more horspower , run in time is from 30min to 2 hours with around a 20% load. that is how i do it and so far no come backs for any internal problems.....
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Location Tampa, FL (A61567)
Location Tampa, FL...
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
