Very small floating dock ideas
   / Very small floating dock ideas #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I need to make a small floating 'dock' to hold a wireless pond water temperature sensor and battery/solar panel setup (less than 10 pounds of total weight). I need it to be stable and not flip in the wind. I thought about getting a dock float but that seems like overkill and is too big for what I need. Any ideas on a DIY float?
   / Very small floating dock ideas #2
cardboard box , saran wrap , spray foam, you can custom build the float around or make a nest for the equipment and the saranwrap will protect it .
   / Very small floating dock ideas #3
There are several companies that ship frozen foods in fairly large heavy duty Styrofoam containers. Those would probably need a coat of paint to make them last in a pond.
   / Very small floating dock ideas #4
My grand parents used to live on a lake in FLA and their floating dock, much bigger then what you need, was made out of wood sitting on top of big blocks of styrofoam.
If you can't find some old styrofoam laying around, I have seen sheets of it at Lowes sold for insulation. I suppose the other foam insulation would float but I have not tried. Any way, you could just make a floating box out of foam, wood and maybe add something heavy as ballast, say rocks, or a brick but the battery would likely work just fine, to keep the "float" from blowing over. You could also anchor the float, which would also help with the wind issue, with some bricks or cinder block and some line.
Later,
Dan
   / Very small floating dock ideas #5
Just make a square out of 4" or 6" PVC pipe.
   / Very small floating dock ideas #7
Shucks, buy a 2 ft X 8 ft 3 " thick slab of blue or pink foam board, cut in half and make up a 4" X 4" float.
Simply use one sheet of plywood and make a big sandwich and and you will be good to go.
Such a float would even serve to hold probably 2 sun bathers LOL.
Made one or my mom for my mom as a destination 'swim to' and it has lasted some 12 years and still good to go.
   / Very small floating dock ideas #8
Inner tube with a rope tied to a concrete block for an anchor. You can figure out what you need for a deck or mounting surface but a board and some more rope?
   / Very small floating dock ideas #9
Go buy a foam noodle at the dollar store and make a loop. Use a small piece of pvc or dowel to stick the ends together.
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
case 370 glass door never installed (A56436)
case 370 glass...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A57453)
2005 Hino 268...
Toro (A56857)
Toro (A56857)
