Very Jumpy Hydraulics
/ Very Jumpy Hydraulics #11
Both buckets had the same problem. I do think the problem was worse with the bigger bucket though.
Wow, Nice bucket for moving some snow!
Are you able to take some video of this? Does it do it with both curl down and boom down? or just boom down?
In this video Compact tractor max lifting test XJ 225 - Forks vs Bucket vs 6lbs bagged concrete - YouTube @ 5:45ish with the forks and @15:00 with the bucket, I was lowering the load of concrete bags. I didnt feather it well and about lost the load but its very "jerky" because of the weight. Is this similar?
/ Very Jumpy Hydraulics #12
Learned too much flow can be hard to control but factory systems should be all sized for each other part. Friend who owns tractor shop recommend flow control washers for me once on a system to help with such an issue. But a question I have as a person who does not live in snow country and seldom do we have days that are not into at least low 40s as this time of year about 55 is our average high...but if there is water in the hyd oil had would it act in your temps? I know here water in hyd oil in hot weather it can basically think turn into steam it seems but it is different viscosity and flows totally difference and makes for jerky operations. So suggestion you check your oil for water in it. At first wondered if could there be ice in the system affecting the flow but would think the system would soon get hot enough to melt any ice.
/ Very Jumpy Hydraulics #13
Is the problem affected by the tractor throttle setting (which would impact hydraulic flow rate)? Is the loader motion smooth when the valve is opened wide but jumpy when opened to small settings? If so it may just be that the valve isn't particularly smooth operating -- it may crack open and close more abruptly than you are used to.
Years ago when test driving tractors I remember that some had better loader valves than others. I sort of take for granted how smooth the valves are on my Kubota, but when I use a neighbor's (different brand) tractor it feels like the valves are on/off switches. They have absolutely no precision feel to them, and are impossible to use smoothly.
Testing loader controls is something I really really advocate when shopping for new tractors. It's easy to overlook. Unfortunately some brands are not really paying attention to the quality/feel of their loader valves.
The dealer came over and picked up my tractor. The rear remote valve lever was repositioned into the correct slot and the loader hydraulics were fixed as well. This all seemed good until I learned remotely that the dealer was complaining about providing free pick up and delivery service. Since both issues did not need to happen if the dealer would have given the tractor a good once over before the sale, I was not sympathetic as it took a good 4 weeks for the dealer to add the rear remote valves in the first place.
I feel the attitude changed significantly for the worse after the check was cashed to purchase the tractor.
/ Very Jumpy Hydraulics #15
They put the rear remote lever in the wrong slot?! I didn't know that was even possible. So we assume that the control operation passes muster now. Hopefully now you can enjoy your new tractor. Hopefully you and the dealer come to a workable understanding on how your relationship should continue.
The lever was initially installed next to the seat. The top of the lever was angled toward the seat so my thigh was bearing on top of the lever which was more than uncomfortable. A quick test drive from the dealer should have invoked a questioning attitude - similar to trying out the loader before shipping out to the customer.
/ Very Jumpy Hydraulics #17
Is it possible the dealer was upset with his people not doing the job correctly and costing the trip? One way to address with the dealer is to ask the question, "man, shame the valve and levers did not get installed properly. Cost you in correction and me in concern with tractor and wondering about my purchase."
Point out both of you were harmed and costing both of you but...it was they who caused the problem. Don't rub it in but fine to say it in normal voice just as matter of fact and leave it alone. If there is a compliment you can give or such follow up the fact with how much better the operation is now.
The dealer is pretty small - very few people & mostly family.
It also did not help when they took the tractor, they damaged my 10' wide overhead door jamb by turning too sharp and hooking the bucket on the trim. I am convinced that the owner knows nothing of the event. I am debating if I should repair the damage in the Spring or file a claim and bill them for their action.
/ Very Jumpy Hydraulics #19
That ship may very well have sailed if you didn't tell them about it right away. Still it is best to open a dialogue with them. You are really in this together. The folks in Bonduel?
LOL - Direct Hit! Kevin, Josh & Scott
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
1607 (A57192)
1607 (A57192)
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A60736)
2012 BRUMLEY...
