VERY expensive beet juice!
   / VERY expensive beet juice! #121
Methanol is usually available in 55 gallon drums from fuel distributors, at least in my area. It can also be purchased at race tracks.
WWF is no muss no fuss but unless you like blue or orange dye, there is practically no difference between WWF and appropriately diluted methanol. You can dilute the methanol in the tire so it really is just a matter of measuring the amount and pumping it into the tire via a burp valve followed by the appropriate volume of H20.
yep.. available in bulk here to from most fuel distribuitors. that and AF, oil, and even diesel by the barrel.
soundguy
   / VERY expensive beet juice! #122
Starting with some form of alcohol-water mix, are there any types of solids that can be dissolved into the brew to increase the weight that wouldn't be corrosive, or worse? .
You'd have to address solubility, stability, corrosivity and perhaps other issues. Why bother? Alcohol water mixes are basically 8lbs/gallon and we typically get maybe 45-50 gallons into each rear tire. With a total of 100 gallons being 800lbs of ballast even if you could add something to increase the specific weight up to 10lbs/gallon you are only gaining extra 200lbs. If 5000lbs is critically better than 4800lbs for a tractor, then just eat a few more Big Macs instead.:cool:
No question the champion for cheap and heavy is CaCl at 10.8lbs per gallon so if max weight is really necessary then bite the bullet on the potential downsides of CaCl and go that route. However, for just generally adding ballast to a CUT, water/alcohol is a pretty cheap and simple and proven DIY method with very few if any downsides.
soundguy
I found a racing fuels place and will find out what they will sell it for. I'm going to call my fuel oil supplier as well.
   / VERY expensive beet juice! #124
So who is creating the spreadsheet?
Beet juice
$ per gal x install cost.......variable avg flat repair
WW/methanol
$ per gal x install cost......variable avg flat repair
CaCI
$ per gal x install cost......variable avg flat repair + replacement rim in 25-40 yrs
I think CaCI will win that cost comparision
   / VERY expensive beet juice! #125
Beet juice
WW/methanol
CaCI
CaCl clearly beats Beet Juice by that calculus. Not so sure about cost/gallon compared to methanol mix though. I think Methanol mix wins the cost per gallon though CaCl might draw even on cost/pound. Need to consider cost of about 200-300lbs of salt ($75-150) plus inner tube ($50-75x2)and installation (pro or buying tools) for CaCl compared to just buying a burp valve ($8) and methanol for the methanol mix. Methanol is $100-125 for 55 gallons which is plenty for even Canadian weather.
   / VERY expensive beet juice! #126
...just eat a few more Big Macs instead.:cool:
Well, there it goes. I'm a vegetarian. I could go for a little more IPA (having one now with my lunch), but still would be concerned with the 'high' center of gravity.
Here in SW Washington (under 300 foot elevation), we get few long hard freezes, though it's not unheard of. Freezing such a large volume of water would take some time. I don't think it would require a heck of a lot of alcohol here most years.
   / VERY expensive beet juice! #127
For ag tractors (tillage) extra weight is a given, be it suitcase or liquid.
But is it all that important for these new fangled:D CUTs that mows lawns, moves snow, or ventures into the forest for firewood? A set of tire chains is WAAAY cheaper than anything you put on or in your machine to increase its weight.
   / VERY expensive beet juice! #128
Please tell me the source for cheap tire chains for my rears. Really could use some when it snows.
My ground is bumpy and up and down. One of my first impressions of my newer, bigger, tractor was, "hmmmmm, tippy!"
DAY, this isn't as much about traction on snow for me as it is about overall stability - lower CG and ballast for loader work and for digging. It is always nice to have ballast on the 3PT but there are going to be situations when you don't have it and then it is nice to have weights on the wheels or ballasted tires.
I know I saw a HUGE difference in loader capability on my current L3400 and stability with loaded tires.
I'm not fond of the hassle of dealing with leaking fluid but I think the benefits outweigh the downsides for me.
   / VERY expensive beet juice! #130
I see your point, about CG and traction- esp for loader work.:thumbsup:
Not to beat a dead horse, but (A) we are trying to make one machine do many, many different things, and (B) how come the manufactures sell tractors that need to be modified, right out the showroom door?:confused2:
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
