VERY expensive beet juice!
   / VERY expensive beet juice! #351
rScotty, agree with you bud, could not imagine should you get it a leak and that methanol squirt on the exhaust manifold.
   / VERY expensive beet juice! #352
If you want to bump a thread that has been sitting dormant for six months you could at least quote the post you are talking about so we can see where in 350 posts you are talking about. :irked:
   / VERY expensive beet juice! #353
:mad: your right, did not think of it or note the date of the post.
   / VERY expensive beet juice! #354
Hey your a newbie your allowed some internet indiscretions. I didn't note your post numbers so can't brag .
   / VERY expensive beet juice! #355
Oh, I don't think it makes much difference when a thread revives.....some threads are timeless. Anything with 36 !! pages must have something of value - or at least we hope so. The question of "if" and "what substance" to put into or onto your tractor tires is probably as relevant now as it has been for years....if not decades.
Lots of debate and few conclusions makes it fun to explore.
rScotty
   / VERY expensive beet juice! #357
No, no, no!!! That DIY formula with soap and ammonia is fine for cleaning windshields but would freeze solid at about the same 32 degrees as water. Methanol is the key ingredient of WWF that makes it appropriate in below freezing conditions for use as ballast in tractor tires. IIRC, WWF must be roughly 30% methanol to drop the freezing point to -10 or 20 degrees F.
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
