vertical storage of rotary cutter
   / vertical storage of rotary cutter #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
I would like to store my 5 foot rotary cutter in a vertical position during the winter season, so it takes up less floor space in my shed.
I'm contemplating building a stand with some heavy duty wheels and a support bracket of some sort to keep the cutter vertical. Obviously, it will have to be heavy duty and stable enough to safely secure the 500 lb cutter.
It could also possibly double as a maintenance accessory, to hold the cutter in a convienent position for blade sharpening, etc.
Has anyone done something similar? Is there perhaps a commercial product already available that I should consider?
Thanks,
Tom
   / vertical storage of rotary cutter #2
How about a cheepo chain hoist and just crank it up against a wall?
chain hoist
   / vertical storage of rotary cutter #3
I think it would work fine.
But do take note of where the vent is, and if gear box oil runs out don't forget to add as needed after you put the mower back down flat on the ground.
Would be a shame if you stored it so nicely over the winter, and lost the gear box because you forgot to check oil level in the spring... /forums/images/graemlins/smile.gif
   / vertical storage of rotary cutter #4
My guess is that a lot of us store our mower decks in a vertical position over the winter - I do. I have five 2'x5' platforms that I store my implements on - one each for a snowblower, a rotary broom, a rotary tiller, a dozer blade and an aerator. The snowblower and mower deck share the same platform as they are used in alternate seasons. I use two 2"x6" stringers and four 2"x6" cross pieces (both on the flat). The top is 1/2" plywood. Each platform has four 3" rubber casters, two that swivel and two fixed. I store them with the narrow edge against tne back wall of my garage. This allows me to access whichever implement I need at the time. I don't know of any commercial made units but there may well be. But making your own is probably much cheaper.
   / vertical storage of rotary cutter #5
Henro,
Yes my Bush Hog brand cutter has a vent hole in the filler plug and if I stored it vertical I would loose most of the grease in the gearbox. It is a tiny hole but grease will come out over time.
   / vertical storage of rotary cutter #6
Could you just put a bolt in it for the winter storage?
   / vertical storage of rotary cutter #7
Hmm, now that is a thought... maybe not a bolt, but a pipe plug with no hole in it...it is about 1 inch pipe plug......Good Idea there, not sure why I did not think of it besides being brain damaged /forums/images/graemlins/smile.gif
Of course on second thought if I forgot and left the other ventless plug in there when I pull it out of storage next year... well there go the seals as soon as the box warms up, then my grease, then ,my gearbox... hmm think I will just store mine flat.....
   / vertical storage of rotary cutter #8
I have been thinking about pallet racks. Much like what you see at lowes or home depot. Like:
http://www.cisco-eagle.com/miva/merchant.mv?Screen=CTGY&Store_Code=CEI&Category_Code=kit96
That way you could stack several maybe a very heavy implement on the bottom, another on a middle shelf, and a lighter one on top like a cosmo seeder.
You can buy these things with very high load ratings; 1000's of lbs/ shelf.
Only problem is you need a set of forks and a pretty good loader to stack the implements on the shelves.
Not free, but cheaper than a new shed or addition to the barn.
Fred
   / vertical storage of rotary cutter #9
Should work fine.. every dealer I've seen except TSC stores their cutters vertically stacked up agains fences.. etc.
Just check your gearbox oil level. That pinhole in the vented cap is bound to leak some oil
Soundguy
   / vertical storage of rotary cutter #10
I have mine stacked like that against the side block wall. And soundguys correct some gear oil does leak out but its a small amount.
   / vertical storage of rotary cutter #11
<font color="blue"> "Of course on second thought if I forgot and left the other ventless plug in there..."
<font color="black"> Maybe you could weld a T-handle to the storage plug that sticks out far enough to remind you?
Or hang a note on one of the attachment points that you have to remove to hook up the mower.
This getting old isn't as much fun as I thought it would be.
   / vertical storage of rotary cutter #12
Getting old is not fun, however it beats the only other alternative /forums/images/graemlins/smile.gif
   / vertical storage of rotary cutter #13
<font color="blue"> Getting old is not fun, however it beats the only other alternative /forums/images/graemlins/smile.gif </font>
That's for sure...but tell me...I've been retired for almost four years now...fortunatly it started early at age 54...but I still have not figured out when getting old starts...anyone?
Maybe it's like beauty...all in the eyes of the beholder... /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
That being asked, I can report that I have noticed that I'm not as good as I once was, but I'm as good once as I ever was... /forums/images/graemlins/blush.gif
Could this be a sign? /forums/images/graemlins/shocked.gif
   / vertical storage of rotary cutter #14
I had a some left over 2x4s and plywood from a concrete project. They were used as forms. So instead of tossing them I made my own pallet rack. It's 8' high x 30" deep x 60" wide. The size was determined by the space available and the size of the implements to be put on it.
On the top shelf I have a small snowblower and rototiller (turned sideways and hanging off the shelf front and back). On the bottom shelf a larger snowblower and the middle shelf has the PTO generator.
It worked out great and cleaned up the implements that are not used very much.
In fact I made my own pallets from the remaining smaller bits of 2x4 and plywood.
I put castor wheels on the rack so I can roll it over to the garage door to get better access for the bucket forks.
In the winter the big snowblower will be swapped for the MMM. Prior to this I sometimes tied the MMM up against the wall.
Rich
   / vertical storage of rotary cutter #15
Sure can relate with that. Now it takes me all night to do what I used to do all night.
   / vertical storage of rotary cutter #16
Henro;
Can relate to your situation. Retired 4 months and can't remember when I had time to go to work. All I can say is Wisconsin has four seasons and one great retirement system. Thank god for direct deposit or I'd forget to cash the check !!
   / vertical storage of rotary cutter #17
Rich,
Sounds like a neat solution.
If a man could weld well, which excludes me, it would be a snap to make some out of steel. Steel would probably allow for higher loads per shelf.
Fred
   / vertical storage of rotary cutter #18
I've thought of getting some racks like that for the same purpose. (I guess I ought to build a shed first so I have a place to put them.) /forums/images/graemlins/grin.gif Sometimes you can find them at a considerable savings if you find a warehouse or factory that is having a "going out of business" auction.
   / vertical storage of rotary cutter #19
Every "going out of business sale" I've been to I've asked about the shelving. Everytime I get the same answer. Not for sale or Already sold.
Rich
2020 DRAGON ESP...
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
(2) USED 3500 LB TRAILER AXLE W/ BRAKE (A60432)
(2) USED 3500 LB...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
