Vertical exhaust
/ Vertical exhaust #1
pilot-werx
Southern Maine
Does anybody know where a vertical exhaust for a 4210 can be found? Does anyone make them?
Thanks,
Chris
/ Vertical exhaust #2
The current JD 3000-4000 machines have a circular cut-out on the underside of the hood (maybe the 2000 series, too).
Owner's have the option of buying the exhaust pipe and the edging material (cover the hole) for their dealer and installing the vertical exhaust themselves.
Does the hood on your 4210 have the hole-thru option? If not, you may need to install a side-panel exhaust pipe. Similar to the type on the older 50 and 70 JD CUT's.
Give your dealer a call and see what they recommend.
AKfish
/ Vertical exhaust #3
Ditto on giving your dealer a call.
Check out JDparts, it shows a vertical.
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
KUBOTA LA535 FRONT LOADER ATTACHMENT (A64280)
KUBOTA LA535 FRONT...
