Vent"s problem
/ Vent"s problem #1
MfLuke
Čakovec
Mf Fe-35
Hi everybody;)
I am from Croatia and I have problem.
Does anybody know what is the height of vents with regard to head of motor for Mf Fe-35, 1960, 4 cyl, perkins motor, 29 kW?
(Sory for bad english)
/ Vent"s problem #2
Not sure what you are refering to when you say 'vents'. Are you refering to the 'valves' in the head because you are grinding the valves or the valve clearance/gap?
/ Vent"s problem
Yes I mean valves. Have you got answer?
/ Vent"s problem #4
Not off hand and there maybe someone on the forum that has that answer more readily than I.
Just to be clear, are you grinding the valves and you want the distance between the head surface and valve face?
/ Vent"s problem
Yes, that distance is problem. I donˇt know how much milimeters must be this distance?
My ventil have distance 2,5 - 3mm, but i think it"s to much.
/ Vent"s problem #6
It looks like you are within range. I added an attachment showing the valve setup and specifications, but not sure you can read. View attachment 370755 ForumRunner_20140415_213151.png
The clearance valve to head: 0.070 to 0.140"/1.78 to 3.56 mm
Valve to rocker clearance: 0.010"/0.254 mm both intake and exhaust.
I hope this helps.
/ Vent"s problem
Thak you very much. But is it same at 4cylinder tractor? My tractor is 29 kw and 4 cyl;)
Do you might have picture of this( I don´t know how you call it) but for Mf Fe-35?
/ Vent"s problem #8
First off, I neglected to welcome you to TBN.
I was not paying attention to the fact that it is a 4 cylinder diesel. It should be a Standard diesel and I can get the information for you in a day or 2.
/ Vent"s problem
You do not have informations for 4cyl diesel?
/ Vent"s problem #10
Valve face to head: 0.040"/1.02mm below head surface.
Lash Intake: 0.012"/0.305mm
Exhaust:0.008"/0.203mm
/ Vent"s problem #11
Here are the pages
/ Vent"s problem
Than you very much:)
Can you tell me how you call this(picture is under tekst), and do you might have this but for Mf Fe-35?faza.jpg
/ Vent"s problem #13
I have looked for something other than the pictures I have provided, but do not have anything. The information I provided is for the MF35 which is the FE35. Both utilized the Standard Diesel 23C.
