Loader Valve Lock
/ Valve Lock #1
RockingSTAR
Kingston, TN
Kuboda B2620
I just recently traded in my old Kubota B7200 for a B2620 with a LA364 front end loader and I love it! however I can't get the valve lock to work. It has a lever to lock out the front end loader control so you don't accidentally cause it to move when you are doing something else. I can't even get the lever to move and was wondering if anyone else had experienced this and what it took to fix the problem?
Thanks for any input.
/ Valve Lock #2
The same thing has just happened to my tractor with a LA1002 loader. Did you get any answers to how to unstick it or anyone out there have answer?
/ Valve Lock #3
... Did you get any answers to how to unstick it or anyone out there have answer?
Old Maggot, the other guy, Rockingstar, was referring to locking the stick in place so it doesn't move. But are talking about getting the loader to be "Unstuck"??? is the stick not moving (thus, loader is not moving)?
Let us know... teg
/ Valve Lock #4
No, I was talking about the valve lock being stuck where it would not work. It will not go in or out. My lever will move without it, so the lever is not stuck. I guess I don't need it. Thought maybe was some trick to it rather than forcing it.
/ Valve Lock #5
You're talking about the lever that makes the loader valve not function? Under the seat on mine.
I'll test mine tomorrow. Haven't messed with it yet.
Sent from my SAMSUNG-SM-G890A using TractorByNet
/ Valve Lock #6
I bet if it was sitting for awhile it's probably just rusted. The one on my l3200 just has a metal rod that slides through a collar that's maybe an inch wide or so. I could see it definitely getting stuck there.
/ Valve Lock #7
Anyone have a answer to this? Im constantly replacing the block because my tilt is constantly broken. You can see the rod isn't in the correct spot. This is not allowing the loader to lock
Mike
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
