Loader Valve Lock
/ Valve Lock #1
RockingSTAR
Kingston, TN
Kuboda B2620
I just recently traded in my old Kubota B7200 for a B2620 with a LA364 front end loader and I love it! however I can't get the valve lock to work. It has a lever to lock out the front end loader control so you don't accidentally cause it to move when you are doing something else. I can't even get the lever to move and was wondering if anyone else had experienced this and what it took to fix the problem?
Thanks for any input.
/ Valve Lock #2
The same thing has just happened to my tractor with a LA1002 loader. Did you get any answers to how to unstick it or anyone out there have answer?
/ Valve Lock #3
... Did you get any answers to how to unstick it or anyone out there have answer?
Old Maggot, the other guy, Rockingstar, was referring to locking the stick in place so it doesn't move. But are talking about getting the loader to be "Unstuck"??? is the stick not moving (thus, loader is not moving)?
Let us know... teg
/ Valve Lock #4
No, I was talking about the valve lock being stuck where it would not work. It will not go in or out. My lever will move without it, so the lever is not stuck. I guess I don't need it. Thought maybe was some trick to it rather than forcing it.
/ Valve Lock #5
You're talking about the lever that makes the loader valve not function? Under the seat on mine.
I'll test mine tomorrow. Haven't messed with it yet.
Sent from my SAMSUNG-SM-G890A using TractorByNet
/ Valve Lock #6
I bet if it was sitting for awhile it's probably just rusted. The one on my l3200 just has a metal rod that slides through a collar that's maybe an inch wide or so. I could see it definitely getting stuck there.
/ Valve Lock #7
Anyone have a answer to this? Im constantly replacing the block because my tilt is constantly broken. You can see the rod isn't in the correct spot. This is not allowing the loader to lock
Mike
EZ Trail 3400 (A63688)
213101 (A64276)
213101 (A64276)
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2012 Volkswagen Passat Sedan (A61574)
2012 Volkswagen...
2007 Jeep Wrangler SUV (A61574)
2007 Jeep Wrangler...
