Valve Lash
/ Valve Lash #1
SABULA FARMER
Pennsylvania
Bobcat CT335SST
Does anyone know what the valve clearance is for a 2615?
I appreciate any information you can provide.
Thanks.
S.F.
/ Valve Lash #2
Intake valve tappet clearance (cold) is .25mm --- .009 inch
Face angle is 45 degrees
Valve head edge thickness (minimum) .5 mm --- .019 inches
Valve recession below head surface .5 mm --- .019 inches
Maximum service limit 1.5 mm --- .05 inches
Valve stem to guide clearance .10 mm --- .0003 inches
Exhaust Valve info is the same except for
Valve stem to guide clearance .15 mm --- .0005 inches
/ Valve Lash
Thank You sir, I appreciate it.
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
