Valve Lash
/ Valve Lash #1
SABULA FARMER
Pennsylvania
Bobcat CT335SST
Does anyone know what the valve clearance is for a 2615?
I appreciate any information you can provide.
Thanks.
S.F.
/ Valve Lash #2
Intake valve tappet clearance (cold) is .25mm --- .009 inch
Face angle is 45 degrees
Valve head edge thickness (minimum) .5 mm --- .019 inches
Valve recession below head surface .5 mm --- .019 inches
Maximum service limit 1.5 mm --- .05 inches
Valve stem to guide clearance .10 mm --- .0003 inches
Exhaust Valve info is the same except for
Valve stem to guide clearance .15 mm --- .0005 inches
/ Valve Lash
Thank You sir, I appreciate it.
