Valve Lash
/ Valve Lash #1
SABULA FARMER
Pennsylvania
Bobcat CT335SST
Does anyone know what the valve clearance is for a 2615?
I appreciate any information you can provide.
Thanks.
S.F.
/ Valve Lash #2
Intake valve tappet clearance (cold) is .25mm --- .009 inch
Face angle is 45 degrees
Valve head edge thickness (minimum) .5 mm --- .019 inches
Valve recession below head surface .5 mm --- .019 inches
Maximum service limit 1.5 mm --- .05 inches
Valve stem to guide clearance .10 mm --- .0003 inches
Exhaust Valve info is the same except for
Valve stem to guide clearance .15 mm --- .0005 inches
/ Valve Lash
Thank You sir, I appreciate it.
2201SFL (A64553)
2201SFL (A64553)
2021 John Deere 4044M (A64126)
2021 John Deere...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
Spirit Bike (A64557)
