valve gasket for F 1900
   / valve gasket for F 1900 #12
   / valve gasket for F 1900 #13
Your terminology was correct and the illustration was not necessary. While you are there though, you should adjust the valves. I don't have the clearances off hand, but maybe JC would volunteer those as it looks like he has them handy
   / valve gasket for F 1900 #14
Please look at the attached files on how to do a valve adjustment.
I don't know if I believe that "valve adjustment while engine is idling" that's what the manual says it, You can certainly screw the valves up while doing it hot. i think that is dangerous and crazy. As far as I know valve adjustment is done cold. I have put my #1 piston on TDC and then checked it with my feeler gauge, Then I turned my #2 piston on TDC and checked for intake and exhaust valve lash spacing. Saying that and I only did it once and it was close to the specs so made no adjustment.
  • #1 piston TDC.pdf
  • 1700 vave lash adjustment-owner's manual.pdf
why is gasket #25 175$ and the larger gasket is $34?
   / valve gasket for F 1900 #17
Because the part is not used on many models and this tractor is old. But #25 can be had aftermarket:
its not a complete circle. This may be a stupid question but, could I just get the same 30$ gasket and cut it to lenth?
   / valve gasket for F 1900 #19
What’s not a complete circle?
there are two gaskets. one is a circle around and the other isnt
Man Basket (A47371)
Man Basket (A47371)
MISC PIPE (A48992)
MISC PIPE (A48992)
New/Unused Pallet of 5 Binder and 10 Chains (A48837)
New/Unused Pallet...
2017 FREIGHTLINER M2 BOX TRUCK (A50046)
2017 FREIGHTLINER...
STORAGE FEES (A50046)
2017 Ford F-250 Ext. Cab Reading Service Truck (A48081)
2017 Ford F-250...
