valve gasket for F 1900
   / valve gasket for F 1900 #12
   / valve gasket for F 1900 #13
Your terminology was correct and the illustration was not necessary. While you are there though, you should adjust the valves. I don't have the clearances off hand, but maybe JC would volunteer those as it looks like he has them handy
   / valve gasket for F 1900 #14
Please look at the attached files on how to do a valve adjustment.
I don't know if I believe that "valve adjustment while engine is idling" that's what the manual says it, You can certainly screw the valves up while doing it hot. i think that is dangerous and crazy. As far as I know valve adjustment is done cold. I have put my #1 piston on TDC and then checked it with my feeler gauge, Then I turned my #2 piston on TDC and checked for intake and exhaust valve lash spacing. Saying that and I only did it once and it was close to the specs so made no adjustment.
  • #1 piston TDC.pdf
  • 1700 vave lash adjustment-owner's manual.pdf
why is gasket #25 175$ and the larger gasket is $34?
   / valve gasket for F 1900 #17
Because the part is not used on many models and this tractor is old. But #25 can be had aftermarket:
its not a complete circle. This may be a stupid question but, could I just get the same 30$ gasket and cut it to lenth?
   / valve gasket for F 1900 #19
What’s not a complete circle?
there are two gaskets. one is a circle around and the other isnt
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
2022 Gulf Stream Kingsport 248BH Travel Trailer (A48082)
2022 Gulf Stream...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A45678)
2020 KENWORTH T680...
2008 FREIGHTLINER COLUMBIA 120 DAYCAB (INOPERABLE) (A48992)
2008 FREIGHTLINER...
45057 (A48082)
45057 (A48082)
GENERAL ELECTRIC SWITCH BOX (A48992)
GENERAL ELECTRIC...
