valve disassembly LA211
/ valve disassembly LA211 #1
frenchboy
kubota bx2200
Guess I'm going to take valve apart and clean and look. Other than the spring and balls what else goes wrong inside, are there O-rings on the shaft or what? Any help and guidance would be appreciated.
/ valve disassembly LA211 #3
In a previous post I explained or at least thought I did that I have to put lever in exactly the right position to get my bucket to lift. When my tractor was new and for years after I simply pulled to stop and bucket moved as desired. Lately, however, I must pull to stop and then move lever forward very carefully to find the "sweet spot" and bucket will respond but slowly and weakly. After reading many posts about water infiltration and rust I thought perhaps this could be my problem. This is why I thought it might be time to remove valve and give it a proper cleaning and inspection. The parts breakdown PDF does not show great detail and this is why I have posted for additional info before I begin disassembly. Thanks, Kenny
40ft Shipping Container (A64194)
40ft Shipping...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
Generator (A61572)
Generator (A61572)
