V417 Max Lift
/ V417 Max Lift #1
Xfaxman
Super Star Member
Guthrie, OK
Toolcat 5610 G - Bobcat V417 - TORO+Loader
Bobcat is very conservative with their specs, Rated Lift Capacity is 4400 lbs.
So I thought I would check my V417 using these crane scales chained to a tree stump.
Without the bucket and the boom fully extended, at 15 degrees, it took 3940 lbs to raise the back wheels off the ground.
I lowered and retracted the boom a little, the scale showed zero, then lifted again. I saw 5005 then it showed Over Flow.
There would be about 3200 lbs of dirt in this bucket!
Since I can't measure the maximum lift fully retracted, I will weigh the bucket and add known weights in the bucket, until I can open the lift relief valve with the scale hooked on.
/ V417 Max Lift #2
I'm surprised there weren't any replies to this thread, I finally found it from a link you posted from another thread. I'm always impressed with the pics you post of that V417. I never knew about those until you started posting about it.
That is surely some impressive lift capacity, it's nice to be able to extend and retract the bucket like that.
How is the visibility compared to a tractor? It seems that it could be tough to see whats to the right of you with the boom in the way?
I would be very interested in one of those if they only had a PTO! Do you have enough hydraulic capacity to use a mulcher with that? That would be impressive!
I'd love to see some more action photos with the 7' rotary mower you have for it. Do you use that for heavy duty cutting?
/ V417 Max Lift
Especially when stuck in the mud.
See post #5 here: http://www.tractorbynet.com/forums/toolcat/183057-toolcat-vs-v417.html
It is rated at 22 gpm.
I try not to go over 2" brush, it is rated for bigger, but that puts a lot of stress on it. I will pull the bigger ones with this, just ordered, will get here next week.
Buckthorn Puller
Mowing some giant ragweed.
Stuck in the mud.
Lower the boom, raises the front end.
Extend the boom while spinning the wheels in reverse.
Not stuck now!:D
/ V417 Max Lift #4
The lift capacity is not based solely on the hydraulics. It is actually a stability value and is based on tests specified by ASME/SAE/ISO.
/ V417 Max Lift
Yep, stability, that is why I didn't extend the boom when I took this picture that was in the first post. The ground was a little soft and not level.
attachment.php
The front axle does not pivot like a tractor, but the rear axle does. :thumbsup:
attachment.php
Here it is with the boom extended.
attachment.php
attachment.php
/ V417 Max Lift
425406-v417-max-lift-p3200009-jpg
Found a picture of the boom extended and all the way up with an empty bucket:
And a picture of the boom extended and all the way up with the bale spear:
/ V417 Max Lift
Decided to update this old thread. Never did find the max weight it can lift, but here is a post that shows some info with the crane scale: Compact telehandler
