V Teks Loader/ Hydraulics Questions
   / V Teks Loader/ Hydraulics Questions #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
I have a Yanmar 2020D with the V2 Loader. All works fine but am I (new to this) experiencing some weakness in the system around the bucket curl.
I have been using my box blade to scrape up material and then using the loader to pick up the dirt. When digging, picking up material, or trying to pick up rocks, the curl on the bucket is very weak when the 3pt is in the up position. If I lower the box blade a bit I get curl stength back.
Should I test the system pressure?- If so I need to buy a guage and adaptors? Anyone have any idea what the fitting size is? And, where would I hook the gauge to check the system pressures? I assume once hooked up I put a load in the bucket and see what the readings are?
As for the curl being weak when the 3pt is up - is that normal? Seems the 3pt is calling for pressure / fluid while I am trying to use the curl on the loader. It has a blb joystick loader valve with no float or BYD.
I may not be able to really check into this until spring - Its bound to start getting cold here again! - and the ground should be too hard to dig, but I want to get my head around this so I can tackle this sooner than later.
   / V Teks Loader/ Hydraulics Questions #2
If you lower your 3 point just an inch or so how is the bucket curl? If it seems to be stronger there your feedback rod may need adjusting. The feedback rod is what tells your control valve to quit trying to raise higher. If your pump seems a little loaded when the 3 point is all the way up that is another indication the feedback needs adjusting. Whether you need it or not I will attach a page out of the ym220/226 manual showing the adjustment. I apologize for the quality of the picture but that is as plain as it is in my manual. Your 2020 may be completely different. :thumbsup:
   / V Teks Loader/ Hydraulics Questions #3
Scotty, read kenmacs thread last summer about the grapple he installed there is reference to this problem (that I have also btw) maybe you are experiencing the same thing?
I can tell you from experience you will get no sympathy or help from any dealer or installer on the matter if you installed it the way I think you did.
(since its been done that way from the beginning of time with noooo problems whatsoever...) ;) PM me I have an interesting story about it if interested.
I have not re-done mine yet like kenmac did but I will next spring but he/we have determined a PB at the loader control with a dedicated drain pipe going into the sump is the fix for ours anyway, being as how the 3pt pressure is acting on the loader control since its in series on the Jap market tractors anyway.
Yes Winston - exactly. When the 3pt is lowered slightly, power is restored to the curl!. I will take a look at the file you sent over - THANKS!!!
Car Doc - would love to hear the story. Also I did not install the loader - it came that way. So it is set up like all of the VTEK loaders I am pretty sure. I am getting pretty good with lowering the 3pt a bit but its a pain and when I lower it and it lowers the box blade, I sometimes start dragging and its a little more dangerous when going over uneven ground. I will search out the Kenmac thread and post it here if I find it for posterity. Thank you
   / V Teks Loader/ Hydraulics Questions #5
Yup the whole idea of us having to pay attention the where the 3pt is at to get the loader to work right is where I get rubbed raw= I say the **** with that jmho. :mad:
Cardoc - Yeah....I agree.....but it seems that its pretty costly to fix. I would need a new loader valve at a minimum.....no Power beyond capabilities and no float in mine....so thats about $300 just to start. Add in the fact that I am a hack when it comes to hydraulics......and I can hear the cash regsiter - CA CHING!
   / V Teks Loader/ Hydraulics Questions #7
That's too bad. Well maybe Winston is on track to helping you, what he posted sounds plausible as an explanation and may be the best work around for the problem hope it works!
My draft control has no effect on my 3 pt unless I actually flip the lever to engage it so the adjustment wont fix mine unfortunately.
Going to try to adjust that 3 pt rod.....but do have a question.....
How is the 3pt supposed to work?
1. Does it automatically raise to the full upright position at some point as you move the control lever...OR
2. Does it raise up only to the corresponding amount the control lever is moved?
   / V Teks Loader/ Hydraulics Questions #9
#2, but it may reach full height before the lever is all the way back.
THANKS Winston - I spoke to Hoye the other day and they said that it was more like number 1, but mine sure doesn't act like that and honestly, I like the ability to raise it up in increments so I am glad to hear that its number 2.
Hoye did confirm that when the 3pt hitch is up and wanting to move upwards and cannot (like mine) and the loader bucket is calling for fluid, that it could be dead heading which is not good. So I am going to try to make that adjustment this weekend...Thank you for the photos too!
Oh...Hoye thought that the pump I have would provide 9 gpm - so the pump should be able to handle this.
LandHonor 15,000lbs Hydraulic Logging Winch Skid Steer Attachment (A49462)
LandHonor...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Fork and Frame Skid Steer Attachment (A49462)
Fork and Frame...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
