V belt size????
/ V belt size???? #1
watersteps
David Bradley 917.5121 Terramite T5C
Hello,
I just purchased a David Bradley 917.575121 with a Wisconsin ACN engine. The tractor has 3 belts which I would like to replace at sometime. the belts are 530H, 529H and 7843MI per the manual. Can anyone tell me what size belts I need to replace these belts??
Thanks
/ V belt size???? #2
Hello,
Thanks
No worries,
All V belts are metric so its not a problem find a V belt reseller like NAPA that can measure the belts for you using a V belt gauge and they will provide you the proper new V belts quickly.:thumbsup::):drool:
/ V belt size????
The problem is the belt I have is a 1/2 inch belt this pulley takes a 5/8 belt.
I have been using it and it works fine but, I have decided to replace this Wisconsin ACN with a Briggs or Tecumseh with a recoil starter.
I will be selling the Wisconsin or trading it for a 8 hp Briggs if possible.
Thanks for the info.
/ V belt size???? #4
On your V belt spend the extra money a get outdoor or equipment rated belts. They are meant to have a back idler so they bend and they are fabric covered. Industrial belts are meant to run inline and around larger sheaves.
Craig Clayton
/ V belt size????
Thank you, good advice.
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2019 John Deere R-4038 (A63688)
2019 John Deere...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
PULL TYPE DIRT PAN (A63291)
PULL TYPE DIRT PAN...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
